Selling this parts off my GTR done genuine 34000klm all are in perfect condition
stock turbos+stock dumps $800
stock injectors+fuel rail+reg $400-----SOLD
stock fuel pump $100-----SOLD
stock radiator $60
4 x nismo 550cc injectors to suit SR20 $400
standard air flow meters $300 for the pair
Parts can be picked up at CRD or northern beaches or on the way to gosford, or i can post them at the buyers expense
Edited by NIS.26L
  • Replies 41
can you pls pics of the turbos thanks.
sorry i cant get photos until i pick up the turbos but there isn't much to look at they are r34gtr roller bearing turbos with dumps and actuators
email the pics to [email protected] and I will host and post them for you...
also, if they are still available, would you seperate the turbos?
thanks mate i have emailed the pics
do you want to email pics of the rest of the stuff as well... I'll put it up in here for you.... or otherwise... just open an account at www.photobucket.com and upload your pics there.
they will then give you the links for the pics so that you can put them in your posts the same way I just did above :)
Did the pump go?
I'm still interested if the sale didn't happen :yes:
i havent pick up the pump from CRD yet but it appears to be sold if not i will post it up
