Would you be prepared to sell the turbo's seperately?
And are they a ceramic exhaust wheel... or steel (I have no idea) :D
they are ceramic mate and i want to sell them as a pair
  • Replies 41
sure they fit but do they read the same? maybe CRD could shed some light on this for us if they do... consider them sold !
i will confirm tomorrow,im 99%sure all gtr 32,33,34 standard AFMs are the same even the way they read,if anyone else knows 100% let me know
the dumps are stainless steel not cast im getting alot of PMs asking this, are they better than cast ones? i doubt nissan would have gone backwards when they made these!!!!
yes the airflow meters will work and read perfect on any gtr 100% confirmed
Edited by gtr lm
do you still want them mate?
