  • 1 month later...
Originally posted by Sydneykid
Sorry Dennis, that wasn't me, it was Zahos.  We use NGK BCPR7ES-11 gapped at 0.9 mm in the race GTST.  When it starts missing I spend $18 and buy a new set.  The road car gets PFR5A-11's gapped at 1 mm.   I've not had any problems with this combo and they are cheap enough, so never bothered trying anything else.
Hope that helps.
What do you know the same plug and gap as me!
BCPR7ES-11's gapped to 0.9mm.
I still haven't fully tuned the plug side yet.
The Rule of thumb for NGK plugs I use and many others.
PART 1.
5's for 5,000rpm
6's for 6,000rpm
7's for 7,000rpm
8's for 8,000rpm
9's for 9,000rpm
(Where the rpm is the peak horsepower range of the engine or the peak rpms most commonly used).
PART 2.
Aim for a generous gap when aiming for good peak power.
6's may work at 8,000rpm (If this is where your peak power ought to be) if you close the gap enough. They certainly won't work as well as 8's with a decent gap. The trade off being that 8's won't tollerate around town driving as well unless you give it 8,000rpm around every corner.
It's a basic rule of thumb and not perfect.
For those interested on my opinion of the platinum and iridium plugs; both are better than copper. Only in reliable spark and not in power production (not enough to notice). Get the plug setup wrong and you have to turf them anyway... better a cheap ass copper set than expensive iridiums.
my 2c
    • Everything I found online said never use it because it'll dramatically reduce belt lifespan.  No, but I have seen excessive v-belt tension cause the audible bearing noise from excessive radial load in things like alternators. So don't overdo it. Ideally you set it to manufacturer spec using a proper belt tension guage. I tried the "clicker" type gauges but those cheap things are trash. They read way too low even when you're careful.
    • This is kind of where I've ended up for the most part. It's easier for me, easier for shops that don't have to deal with my weird criteria/picky standards, etc.
    • Will do. Suprised if it's not the starter motor considering it's 30 years old. Will get a volt meter though. Battery is close to new.   Cheers for your help, always appreciated.
    • This almost never happens these days. No. Clean your battery terminals and make sure they are tight. Use sandpaper on a dowel if you have to, to get oxidation off the inside of the terminals, particularly on the -ve. Check the earth cable from battery post to chassis ground and engine ground. Make sure the contact surfaces are clean - including the threads on the bolts that anchor them - because that's where a lot of the contact occurs. Wire wheel on a drill is a good thing for this. Make sure the crimps on those cables are all sound. Assuming none of that causes an improvement: Check the battery voltage after it has been resting for a while. If it's at the lower end of the range, put it on charge for a while, then see if it will crank better.
    • I just checked my belt, it wasn't super loose but I could bend it past 90 degrees a small amount so I tightened it up and for the first time ever my car didn't crank first time, had to crank it again lol. Don't know if that was because I tightened the belt or if it's my starter motor going out (been having slow starts for some time). Coulda also been when I was recording I didn't crank the key properly and it didn't save the recording lol.   Is that a thing if you overtighten a belt it struggles to start?
