Well I have been having cold start issues lately, the thing just starts like a tracktor, see my other posts.
I uses datalogit to see what is goignon, and i can't see anythign obvious, exceppt teh battery voltage dropping to 7.4V. I have seen 6.6 and 8.2 a couple of times.
Can this attribute to starting issues.
The funny things is that it only starts like a dog one, when cold, any other time after that, during the day, eaven in the afternnon, it will be fine.
Basically if ECU temp sensor is below 20 Deg C it starts like a dog.
https://www.sau.com.au/forums/topic/162999-low-cranking-voltage-r33/
hey mate,
it seems as though ur battery is on its last legs, obviously you will find it more difficult to start the car in the colder conditions than when hot. i found that when buying a car battery go for a battery that has a higher cca value. i think cca stands for cold cranking amperage. the higher this value, the more cranking amperage you have and thus the ease at which you can start your car. As batteries get older the cca deteriorates .
best to get a new battery mate,
hope that helps.
cheers
Well the thing is, it's a Hitachi 6 month old battery.
What has been happening.
Basically, when I go to start the car when it is below 18 Deg C, the car splatters, sounds like it’s a bit flooded, revs at 300 rpm, then coughs, splatters and is fine from there.
I have done many things, and over the weekend what I did was to turn the fuel pump off, and pressurize the fuel system with air, to remove all fuel, you will be surprised to hear that the car will run for 2 minutes on the fuel in the fuel rail alone.
So after ensuring that there was no fuel in the rail, or injectors, I was hoping to solve my problems of cold start, but figuring out that it’s a leaking fuel injector.
WELL, I reconnected the hoses, primed the lines and the car still started like crap.
So I figure it’s not the injectors, but can someone shed some light on if what I did could prove that it was not the injectors.
HELP.
I could be your starter motor?
If the brushes are worn and they have also worn the armature then you'll get arcing. This arcing robs the power out of your battery and lowers the health of the spark at the plugs. This means that your spark is dull/weak so your motor is trying to/firing on a weak yellow spark, not a fat blue one. Not sure if this can happen to skylines, but other motors it definitely happens, I've seen it and repaired it [well got the starter motor rebuilt].
If you crank the starter motor over and check the armature at the same time you'll see the arcing, they all arc a bit, but if its bright and strong then I'd get the starter motor checked.
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
