Hi Guys,
I have for sale a genuine ARC intercooler for R32 GTST. It's the side mount intercooler, model number MO75HR32G03 and cost new 98,000 yen + postage or around $1200 delivered. It's used and in fair condition. It could use a good clean up but it's in fine, functioning order. It's 70mm thick. These mount down in your factory intercooler duct so there are no extra piping needed, and no problems with the law. They flow enough and cool enough for around 200rwkw but people have been known to make more. These are a great stealth upgrade and replacing the factory intercooler is a must when increasing the boost on a GTST. I'm asking $350 for it. These don't come up very often and I've had this one for about 8 months, but never fitted it as I was still running stock boost. Now that I've sold my GTST I don't need it anymore. Postage is ~$15 or pick-up in sydney northside. I don't have any pics handy, but it's nothing flash to look at, just an intercooler with an ARC tag on the top and HCR32 written on it next to a serial number.
https://www.sau.com.au/forums/topic/163007-arc-intercooler-for-r32-gtst/
Thanks mate. Yeah ARC are the best in the business. had a few people sniffing around but not firm takers yet. save yourself the hassle of a FMIC, and the weight, and the piping. This gives awesome performance, is a piece of cake to fit and cheap too! can't go wrong.
I can't believe no one wants this. I'll drop the price down to $320.
will this make any benefit to my stock as a rock rb20det (apart from pod filter) as i am in a huge dilema to either get a front mount and up the boost or go for something as ur offering. so much debates on these forums re intercoolers re brands power gains yes or no etc im going nuts.
waht mods did u have on ur rb20det if u wouldnt mind making 200 rwkw cause i want that figure no more prob a bit less. and if this intercooler can handle 200rwkw then im interested.
thanks
yeah it's fine for 200rwkw. that's about as much as I'd go with a side mount though. but it could probably handle a bit more without being a restriction.
my GTST was pretty stock. it's defintately of benefit if you want to wind up the boost a bit, or run a highflow, or R33 or R34 turbo etc.
I Had an ARC side mount cooler on my R33.. and i was running 14psi with no problem. tuned i was making 210kw@ wheels with only a Pod and cat back exhaust.
I sold it and upgreated to a front mound and bigger turbo... I sold My ARC for $500 on ebay.
Thats a Barging at that price, real cheap!
People with R32… U’d be stupid to miss out on something as good as this!
i made 210 rwkw on 10psi hi flowed turbo in my r33 with my arc sidemount. I have a front mount byt im keeping mine sitting in my shed and im planning on holding onto it for now. They are a great intercooler. If you are only after a 200rwkw car and want to keep unreal response this is the key.
Edited by fEkuaR
yeah thanks for the input guys. $500 is on the money. I know I wont be selling mine cheaper than my current asking price. They cost well over $1000 new and perform so well for what they are. plus they keep potential defects away as to the untrained eye they look completely standard and sit in the standard location.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
