Very easy.
The bov bolts on to the pipe as you can probably see. Undo both those bolts and the BOV will come loose. Then that all remains is the plug the plumback hose....Few ways you can do this, but i just use a rubber hose plug from the hardware/marine shop. Pretty easy really.
Im assuming your replacing it with an Atmospheric BOV? If so that is why u plug the plumback hose, if not...tis a bit different.
