Hi Guys,
I'm clearing out stuff as I have more parts than I have money so need to sell some of my race tyres. I have 2 full sets (8 tyres total).
First set:
Yokohama Advan A048R 235/45/17 X 4
These have minimal life left. probably good enough for a few drag days, or a few super sprints just depends on how many laps you are doing. I would say around 15%-20% tread remaining, and it's pretty even wear, no flat spots, or damage, and they are not old tyres so still good rubber. Considering the new cost is ~$1900 15% would be $270 and 20% would be $360. So bearing all that in mind I'm after $220 for all 4.
Second set:
Dunlop Direzza D02G 235/45/17 X 2 and Yokohama Advan A048R 235/45/17 X 2
These have much more life left in them than the first set. The two advans are in very good shape, I'd say 50% tread left. The dunlops are in not quite as good shape, but probably 40% tread left. I'd be using the advans on the front, and the dunlops on the back as GTRs are hard on front tyres. replacement cost on these babies is about the $1800 mark. So given the condition I'm asking $330 for the set of 4. You would get probably half a dozen track days out of these.
I don't have any pics, but can probably get some up tomorrow, but given how expensive these tyres are, and how sought after if you want them, I would just pm me and make a time to come check them out. I'm not really interested in posting interstate but could possibly be presuaded but you would need to organise a courier to collect them from my door.
I'm in sydney in 2 weeks and if I have some room in the car I'll grab em. What suburb are you in and can I have a contact number.
Thanks mate.
Russell
they are in the northshore, chatswood area.
contact number pm'd to russman.
michael, freight to perth I have to be honest I have nfi (i would guess around $120 for a set of 4), but I have to give preference to anyone that can come and collect them from my door. for 2 reasons. 1. it's far easier for me. and 2. i much prefer when people are buying used consumables (tyres, brakes etc) that they get the chance to look at them in person before buying them. I don't think i've oversold them at all with my description, but I would hate for someone interstate to get them and say: "hey, these have 1.8mm tread, not 2mm" etc.
npz.. let me see if i got funds LOL! then i might pm you and go from there if you havn't sold them already :)
cheers michael
not really keen to split a set of 4, unless one of you will take the D02Gs and one take the A048s, feel free to discuss that amongst yourselves via pm. :)
the first set (4XA048) will most likely be sold tonight.
Set 2 (the dunlop/yokohama set) is gone. Set 1 is still available with a few guys circling around. first in with the dough wins. :huh:
still got the first set. need the space badly now. price is $200 flat. will be available for pick-up this weekend. even if you only got one track day out of them it's still a shed load better value than buying new ones. :P
I just got the set left out of the garage for a look see. they are better than I remember. very usable. and no damage, or flat spots, or dodgey wear on them anywhere at all. so price is still $200 flat, or I will just get them put on some rims and use them myself. so that's Advan A048R 235/45/17 X 4 for a measly $200.
I'll take some pics in a min.
May be interested depending on whether a mate is going over to sydney and could pick them up for me this week. I'll let you know.
i would't mind driving it on the street, but I probably wouldn't drive it in the wet unless there was no other way to travel. as with not much tread depth they are not the greatest in the wet. i don't know what the dates are.
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
