hey guys
i recently upgraded my BOV from a apexi item to a blitz item
since iv installed the blitz bov it wont vent, iv taken it apart cleaned it, the piston moves freely with no obstruction and backed off the spring all the way out its only like 3 turns in !!! my previous bov was atmo so i know the system works..
iv replaced the vac line there is no leak and i dont know whats the deal !
i was playing with it all afternoon and it vented like 3 out of 1000 !!! why wont it vent everytime??
car idles fine everything seems perfect cept the fact it doesnt vent all i gets flutter
oh btw this is on rb25 and im running 12psi which should be more than enough to open an un-tensioned bov
so if anyone has any suggestions to how i might fix this cause iv tried everything i can think of
thank you
Jarryd
got it working !!!
i got some 1200grit wet n dry and rubbed back everything to remove any burs or imperfections, used motor oil insted of water of course
put back together with grease insted of motor oil and seems to be working all good now
though i removed the plate that controls spring tension so i hope when i go for a dirve it wont open really early and leak..
so if anyone has the same prob just give that a go and see if it makes a difference
haha point and case , if he has a knock off , then there is the answer to his question . go put your stock bov back on , they arent worth the hassel . unless your prepaired to spend over $450 for something really genuine and decent , otherwise your going to have leaks , idle troubles and just a plain old waiste of time and money
Edited by sky-017
its a genuine blitz bov
it only works in like 1st n 2nd, prob more presure in 3rd n doesnt release...
the spring tension is fine when it works it opens early as like hardly on boost.
the vac is fine it almost sucks my finger off
the internals seem fine i cant find any mechanical flaw in it, ie chips in piston n that
i was thinkin of buyin a new spring?
i got a prac day today and dont want to run flutter !! to much on/off throttle
it just doesnt make sence
btw its the blitz bov with the trumpet with 4 holes
Edited by 2gceffy
can't help you there. It seems very weird. Maybe throw your apexi one back on.
Maybe there's a leak in the diaphragm or something, so when the vac line tries to suck the diaphragm up to release, the air is getting around or through the diaphragm somehow..... Maybe connect a line to the nipple and see if you can simulate it.
Just a guess.
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
