Hi. I have heard of some tinkering with the crank angle sensor and advancing their timing to get a a bit more power.
I've never had the privilege of doing this myself and just wanted to know what the affects would be on doing so with the stocko computer, power, torque, economy, running quality etc.
Thanks
https://www.sau.com.au/forums/topic/163026-advancing-timing/
Retarding the ex timing after mods ie. turbo, hi-flowing exhaust etc can give noticeable gains in all the categories mentioned by you. Advancing ex timing will make less power, torque, response etc. but also make the motor less prone to detonation. If your car is stock it's not worth touching full stop, if your car is modified an adjustable cam gear and tune is a far better idea than DIY CAS adjustment and hope for the best.
that's weird cause in the missus pulsar i advanced the timing from 15 degrees to 19 degrees and it went much better. the problem with retarding the timing is that by the time the fuel has finished burning it may be past TDC. as the fuel burnst it expands, so by advancing the timing you have more fuel burnt by TDC. this however means that the pressure inside the chamber is higher, so the temp is higher (as well as a higher temp from more fuel being burnt). then when it next puts fuel in the chamber temp is higher, so it is closer to pre ignition.
if you retard the timing less fuel gets burnt under high pressure, so there is less heat. while the fuel is unburnt it keeps the chamber cool.
i've done it. advanced it about 5/6 degrees. went much better. i just took it to the point of pinging, then came back a touch. helps build revs faster. you just have to make sure you run the best fuel you can, and always run that fuel.
How can you tell how many degrees your dialing in?
Don't you mean more power and more prone to detonation etc etc?
most of the people out there that say that 200rwkw from a stock ecu/turbo rb25 are probably running stock timing. there are also other things you can do to get more power, but i can't tell you, otherwise i'd have to kill you.
hahaha is that so? You can't kill the unkillable cos i'm invincible.....I think.
Whats TDC?
Shouldn't it be that when its running leaner it runs hotter?
Nope, you guys got it the wrong way around.
Have a read of previous threads on retarding exhaust cam. Plenty of information about it and you don't even have to start a new thread.
http://www.skylinesaustralia.com/forums/in...stable+cam+gear
Wouldn't advancing the cam give you more torque and quicker spool time? As advancing the cam allows the valves to stay open longer, hence more fuel and air can get into the combustion chamber, and also, it allows exhaust gases more time to escape from the cylinder, leading to better breathing abilities, hence more power and less heat generation?
Edited by Marco-R34GTT
Advancing the the ex cam makes the valves open earlier, not stay open longer because the duration the valves are open is dependent on the profile of the cam and that does not change.
A quote from somewhere:
'Where the turbo engine will gain most from cam gears is by retarding the exhaust cam shaft. Normally manafactures like to advance the cam more than optimum for peak power because their highly restictive exhaust manifolds and systems can force hot gases back into the cylinder, promoting detonation.
Start retarding the exhaust cam a couple degrees at a time and watch the power climb, particularly if the engine has a larger exhaust housing on the turbo or an extremely low-restriction exhaust system.'
Funny, in the VL, retarding the cam one tooth and 8 degrees made a massive difference for power when included with even minor mods. About 92kw stock at the wheels, with K&N air filter, twin hyclones, performance extractors, 2.5 exhaust/hi flow cat and an ecu remap, power jumped to an unbelievable 128kw at the wheels. Nothing amazing for Skylines but it made a world of difference for the VL, completely different car to drive... It looks here as if the opposite is true...
Adjusting cam timing = off topic.
Adjusting Ignition timing = ON topic.
Thanks cubes :)
Ok so just to clarify if I'm correct, Looking the engine from the front and turning the CAS:
Advance =anticlockwise
Retard =clockwise
And only adjust the timing while the car is running?
After adjustment put it under load in 5th and check it doesn't ping?
If I'm correct only advance it about 4-5 degrees. Should that be a safe amount running BP Ultimate fuel?
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to come I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
