anyone has any recommened for 19's tyres, good for money? looking for 245/35R19 275/35R19
have quoted new falken 452 (not gb451) for around $1500, but not sure how's the performance on falken? very afraid to get worse tyres due to had bad accident in previous. please give some opinion!!!
Edited by spikey
https://www.sau.com.au/forums/topic/163043-tyres-decision-help/
Falken fk 451 are really really good tyres. You'll be suprised, because they're cheap for how grippy they are (bad english, i'm tired).
I've personally used the 451 and they are the best tyre you can buy without spending crazy amounts of money.
I haven't used the 452. When my tyres need to be changed, I will try them. I'm sure they'll be ok, because they are falken's more upper range tyre.
Whatever you do, do not buy the falken ziex tyres - they're like driving on ice.
The cheapest tyres that you can buy that are decent are the nangkang nsII ultrasport. They're ok in the wet - not as grippy as the falken fk451 though.
yeah the 451s are quite good. I have had the 326s which were not terrible in the dry but were shocking in the wet. I could spin 3rd gear with just in gear acceleration and that's with a bone stock 32 GTST making probably 100rwkw max.
452 and 326 are about the same .
451 are good and so are St 115 ( now superseeded ).
You will find the SP9000 are good .
Whoa, really?
Yeah, jerry, I foudn the st115 and 451 to be very good (one of the better street tyres and not expensive either). If anything, I found the 451 to be a little bit better. Did you find that too?
So the new 452 is no good is it? it's not like the 451? because the ziex 3xx are like death traps. May as well be driving slicks in the wet.
Cheers
Chris
That is very untrue! The 326 and 452 are like comparing apples to oranges. The 452 is the newer model which combines features from the 451 and ST115 (both superceded models). I've got 452s on my 34. Did a fair bit of research on them before biting the bullet and very happy with them both in wet and dry. There have been a fair few positive comments from guys that are using the 452 as well. While the 452 is no ultra performance tyre, its a good compromise between grip and wear. Good mid range tyre for the money. I paid $1100 for a set of 18s in 235 and 265 close to a year ago.
www.fk452.com
There is a comparison between the 451 and 452 on the last slide.
http://www.fk452.com/technicalinfo.html
www.fk452.com
My bad, you are are right 452 is a good tyre. I was thinking of the 512 wich is very similar to 326, both crap .
Chris, I prefer the ST 115 over the FK451, had them both on a 33 GTR but the ST115 was 18" and the FK451 17" so maybe that had something to do with it . I had the ST115 on a rex a few years ago and that was good as well. I found them holding better when half worn.
    • As a general rule removing rubber fuel hose is so difficult I would replace it if it hasn't been done in the last 5 years. The risk you damage the liner or one of the inner layers is pretty high if it's not almost brand new. BMW's recommendations around coolant hoses is similar. My R33's fuel hoses at the fuel tank were so perished that they were ready to burst FYI.
    • Ah yep, will do. Cheers!
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
    • https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.  Discounted tickets 20% off for their various tickets until the 3rd of Feb Monday. Drags, show and shine etc.  I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.  I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.  https://gtrfestival.com.au
    • Does have series 2 airbag steering wheel and passenger side airbag also.
