its a series 1 there's no such thing as a 1.5
it may a lil better stuff such abs etc, but its still a series 1
like others have said to confirm it just post pics of ur interior
we regard series 1.5 as a mix between series 1 and 2. series 1.5 look like a series 1, but have a few things like the ignition system of a series 2.
Front bar is either a Nismo 400R or a UAS Copy... I have the same bar (Nismo).
As others have said ..... Series 1 headlights and bonnet etc... Series 2 wing, interior and engine (coil setup). Unless the series 2 wing has been put on a S1 - pics of interior or ignitor (or lack of) will determine. Technically no such thing as a 1.5 but it's commonly referred to as such... 93 & 94 are series 1 ..... 95 is a bitser but still a S1... 96-98 are series 2
Yeah its 1.5. When I bought my car, the guy who sold it advertised it as a series II. He knocked a couple hundred off the price when I told him its in fact a series 1 lol.
Mine is a sept 95 model so it has a series II engine and airbag but the body is still a series 1 like yours.
I love your front bar btw its one of the nicer series 1 bars I've seen, its not a 400R, i think its JUN as well.
:huh: Will have a look again at mine..... there is a nismo stamp on mine and it looks identical... unless some lil shmuck has done it!
Hey guys,
This probably sounds stupid but how exactly tell the difference between a series one and series two R33 just by looking at it. And is there a difference in performance between the two?
Thanks,
Sammy.
your car is a series 1.5 mate. your headlights are not sharp as the series 2's are. thats how u can tell also :huh:
Yep that's my front bar - its extremely thick at the bottom ... you can scrape it and bump it n stuff and only the paint cracks! Its coming off to be repaired seeing the trolley jack collapsed and made all the paint crack when it hit the deck :huh: Il see if there are any other markings on it whilst its off............ Jun.. Nismo... tis all good!
Hi Guys - sorry i didnt get a chance to read all these other replied til now. I just took these pics of my interior with my phone... that is why it looks so crap... lol
Let me know what it is... Thanks!
Thanks on the comments about the front bar too, glad you all like it :stupid:
Dash looks like a series 1 dash, as the hazard light's hole isnt budged out....but the body kit has a s2 rear and s1 front. :stupid:
Is the ignitor pack sitting at the back of the coilcover? If it is it would be a series 1 engine. Are the seats the S2 Kmart style or the good REAL S1 seats?
But who knows what people mix and match engines and body kits these days...
Dyno it and see what power you get and or do a 1/4 mile run... They are all the same skylines lols
I think it's a series 1.5 though.
I dont think i have seen a 95 with the low 93-94 wing, i think it is a perfect example of a 95 Gts-t Series 1 with a few bits and pieces from a series 2.
Bitsa or 1.5 whatever you wanna call it...
i actually met a guy with a 95 series 1 R33, two tone in colour, series 2 wing and series 2 interior, seats and door trims, but had an aftermarket steering wheel, i forgot to check the instrument cluster and igniter, he said he got the car like that, interesting....
Dash looks like a series 1 dash, as the hazard light's hole isnt budged out....but the body kit has a s2 rear and s1 front. :P
damn kmart interior...
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
    • Good question, I don't really know tbh...I'm pretty stock thought, where could I check this?
    • This. I'm confused by the whole discussion. The only reason you would have a car with e85 only if it was track use and you only ever used e85. All other use cases you add a flex fuel sensor, do the flex tune (you only need to do a couple of % and then interpolate the rest) and then you put whatever the hell you feel like including a mix in the tank and it just works. Want a long drive? fill with 98 Want max zoom? fill with e85 Got a half tank of 98 then find e85 somewhere? Throw it in.
