Hey guys,
i just recieved a set of those blue dash lights from dan666.
The problem is that the only ones that are working are the temp/fuel guage.
I have been stuffing around for hours now trying to get the rest to follow suit.
Are they in sequence, if the first one is out, the rest wont work. The leds do work only way i realise, is there a trick to it that i am missing.
PLEASE HELP!!! :) lol
https://www.sau.com.au/forums/topic/163096-dash-lights/
Worked it out...
It has an aftermarket dimmer switch. When i took the cluster out, I disconnected the dimmer switch. The bulbs went in, then the cluster went back in. Turned everything on but nothing worked.
Because i didnt re-connect the dimmer switch i didnt 're complete' the circuit....
Does yours have a dimmer? On first go only the parkers came on as well, so i pulled every bulb out again and re did them.
I hate LED's :)
https://www.sau.com.au/forums/topic/163096-dash-lights/#findComment-3027018
Yeh...... i have heard that its a dimmer switch i willl go check it out right now! Soo POS and NEG got it! and Dimmer switch!
Awesome thanks crave and sxc i check it out makes sense... however if i take out all the leds and just put one old bulb in nothing (but the dimmer isn't back together!
https://www.sau.com.au/forums/topic/163096-dash-lights/#findComment-3027041
  • 3 weeks later...
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
    • Just putting it out there, that's a decent list. You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
    • Does not mean what you think it means. The continual rising coefficient is the coefficient of friction that continues to rise with increasing temperature. Not "rising during a single stop", except inasmuch as the brakes should get hotter during a single stop. The RR would not be the best choice for a streeter. Yeah....no it's not. JAX would rummage around in the "shit pads we use for all shitboxen that come in here" and install those.
    • @Kinkstaah I've got my list.. but most of them is to do if I ever win the lotto
