hi guys,
I am building and RB2.3 and before i pull my engine apart just want to clarify a few things.
I am using a RB25 crank and rods with 4AGZE pistons from a AE101 levin, as i believe that these are forged & light weight. Now Question time:
1.The piston pin hole dia. is 20mm, is that the same as RB25 rods
2. 4AGZE pistons are 81mm, current bore size is 78mm. that's 3mm or a lotta thou. Is there enough cyl. wall thickness to be bored out that much, also. I have been told that there will be problems with cyl. flexing, just want to know people's personal experiece. I am going to 'Cryo treat' most parts of the engine, so hopefully that should cyl. problems if there are any.
3. Anyone know prices for 4AGZE pistons, must be from a AE101.
Price for 1mm metal head gasket
Price for 'Nismo' Big end crank & con rod bearings
4. 1 more, i am running a HKS 3037s turbo, any advise for camshft selction.
Thanks in advance
https://www.sau.com.au/forums/topic/16311-rb23-clarification/
my honest thoughts on this are just go the 2.2 and get the proper pistons if your going to run a 3037 you will need all the revs you can get tomei make the 2.2 pistons they are 82 mm should be plenty of bore left I know some one who ran this set up with a big rx6 set up and 256 cams and he made 600 hp you will need cams and some head work also consider usinga rb 26 n1 oil pump.
cheers
meggala
http://www.tomei-p.co.jp/
have fun I wish I had the budget to build one a rebuilt 20 will have to do me :P
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
