Hi everyone,
Strathfield fitted an immob (3 point cyclops) and alarm to my car about two weeks ago. When I picked it up, it all worked fine. Then I tried to drive it last night (first time since the installation) and I found that after I switch off the immob and try to start the car as normal, it just makes this clicking sound. It sounds like the starter motor but it also makes a beep every time the starter motor clicks.
Strathfield reckons the battery's dead because I haven't driven the car in two weeks. Thing is, I had a new battery put in when the car came through compliance about two months ago. Does this sound right to anyone?
Sg.
https://www.sau.com.au/forums/topic/16313-immobiliser-question/
I have 3 friends who put that same product in 2 skylines and a commodore...
The installer was also telling one of my friends that he had someone complain about that too (in a Camry) - while he was getting it installed...(and explained that he probably didn't use it properly - as an excuse)
so all 4 people in question had the same problem, and got the same reply...that you have to activate the alarm for it to NOT drain your battery...which can make sense electronically speaking...
HOWEVER...thing is, the 3 of the 4 I know would never have left their car without activating the alarm...
so whether Stratties like it or not, that alarm drains the battery and even with a new battery, the car is dead (or low) after a few days of not driving it...
because they install a lot of them, and most people drive their cars every day, the problem is hidden to them...with only a small handful of people actually going back to complain...the rest live with it...(I hate that part of the population)
who knows, perhaps the alarm is great, and they use some super high-powered flashing LED which is doing all of the draining...or maybe its the sensor sucking the juice out of the battery...
either way the package has a flaw and people should know that it will leave you flat after a few days of not driving your car...
  • 5 months later...
  • 4 weeks later...
If this alarm is is draining the power out the battery, then it's uselss to you.
Sounds like a fault of some sort or they havent hooked it up right.
When I went shopping for an alarm, I asked the question 'Can I leave the car in the city overnight and not get stolen."
Apart from being towed offcourse, i got a Mongoose Alarm installed for $500.
keep the alarm simple, no fancy window wind ups and all that. Less chance of something going wrong.
3 point cutt off, fuel pump, ignition, starter...battery backup warranty and gurantee if car get stolen in first 12 months.
hows that for an alarm co.
Hey sigsputnik, has this problem been fixed by putting in a new car battery? I doubt u would need a new battery after just 2 months. Try jump start it and see what happens.
Also, does the actual alarm unit have a battery in it too?
My car makes that clicking noise under the dash coz the alarm is f*cked, i just disable everything and the car starts fine so i basically have no alarm atm. Just wondering if I have the same problem.
If your battery went flat, normally the siren goes onto the backup battery and starts making noises (I've had it happen when the battery was a bit low, but would still start the car - siren started screaming during cranking).
Try inserting a relay into the starter trigger wire, so it supplies full battery power to the solenoid switch.
  • 3 weeks later...
I'm planning on booking it back into Strathfield early in the new year when it's a bit quieter. I'm not exactly sure what I'm going to ask for yet.
_turtle_: no, it isn't the battery, it's completely sound. Not sure if the alarm has its own battery.
I think I might get them to remove the old alarm and then put something else in. Swordfish, that Mongoose thing sounds great. I guess I just don't trust mine perfectly any more. I'll let you know how it goes.
autobarn installed mine, and since then the airbag light has been flashing, i took it back and they wont fix it!
but my alarm works really well, 4 point system, but i agree with swordfish, no fancy window windups coz obviously they're the ones that will drain your battery and be tempremental.
good luck!!
Id say its your battery, when mine died it did exactly as you described. All I could here was a rapid ticking when i turned the key and the engine would not crank. Also the battery voltage dropped to 7v :Oops:
Perhaps just see if you can borrow a good battery as a test, I stole my dads for a while.
Ive had similar problems before on my old car. Basically it wasnt my daily driver and if I set the alarm on my car and didnt drive it for a couple of weeks the battery would be dead. So I was never able to set the alarm on my car if it was in my garage.
This is why I am considering the Boomerang alarm/immobiliser. That has as part of its system a "voltage" meter and will automatically restart your car and charge the battery if it detects a drop in charge. This can be a damn handy thing if you have a car thats not driven regularly but you want to keep alarmed.
Blummin hell that's clever, AR :(. Still, feels a little like robbing Peter to pay Paul getting the car to start itself to recharge the battery. Surely there must be some way of working out why it's going flat?
Dawg, it isn't the battery. The battery is a brand new heavy duty. This only started happening after the alarm was installed, which was quite a while after the new battery was put in.
hey guys, sigsputnik has said "I found that after I switch off the immob and try to start the car as normal,"
so are you saying that even though when he turns off the immobiliser he can start his car as normal, that the battery on the car is running low? if that is the case then i need to change the battery on my car too but i don't really think so seeing as we can start up the car fine with the immobiliser off.
sigsputnik, get an amp meter, and see if you can trackdown the drain, my cousin wondered why his battery on his commo went flat, and it turned out to be his new sheepskin seat covers holding the electric motor on the VT commo seats on continiously. So sillier things have happend! :D
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
