hey guys. i blew my headgasket on track on saturday night in my cefiro. 1st time out since i bought the car, and it blew. atm its got cam, 25/30 turbo, gtr fuel pump. thats really about it engine wise. i took it to the mechanic and it was running lean so now its got a fuel pressure reg. i was gonna do gtr injectors soon. since i blew the head gasket, theres no point in opening the lid, new gasket, and closing up again. so i thought why not put a few goodies in there. what do u suggest i should do to the motor to just make it SCREAM as a drift car. just be able to THRASH it on track, i dont mean thrash in a bad way, but just make it take a beating. dont need more than 250kw, it was making 195 before head gasket went on 17 pound.
so basically i want a very strong engine, all internals strong. so i can keep it at 250kw and make it love to scream on the track. i really think that if i do it once i may as well do it right and get it running sweet.
help me out guys :) i know its gonna cost alot..... i cant really afford anything over 5 grand.
https://www.sau.com.au/forums/topic/163146-my-rb20-cefiro/
Just put a set of pistons in there and good bearings.
Make sure the crank/rods are tested before reinstalling it. Just incase there is undue stress which isnt a good idea to re-use them.
Slight port/tidy up of the head and thats about it really.
Not a lot required to hold 250rwkw reliably in the RB20. Just good pistons/bearings seems to be the go :)
That should be smack on your budget there too, thats if you remove/install the motor yourself.
https://www.sau.com.au/forums/topic/163146-my-rb20-cefiro/#findComment-3027562
Im with Nismoid. A freshen up of the bottom end with good bearings and some 40-80thou oversized pistons. Rather then headwork i would simply match port the manifolds and clean up the casting of the std head.
I would tweak the oil pump with a higher rate spring to get a bit more pressure in the system. Sell the 2530 and grab a TD06 setup. Similar response but way more power.
But in all seriousness...while the engine is out i would have the mechanic inspect the motor. Odds are you will just need a new head gasket and you can use your 5k for entry,fuel, oil and enjoying your car.
At the power you are chasing it is well within the window of where an RB20 can reliably run. The money could be best spent making sure you are running the type of ecu that the best tuner in your area can use
https://www.sau.com.au/forums/topic/163146-my-rb20-cefiro/#findComment-3027601
Troy,
What sort of oil pressure would you look at achieving?
I bought a s/h oil pump that was an new condition (no wear) from a blown rb25det with forgy's. Bad tuning killed it.
Over ~3500-4000rpm it runs ~85psi. When cold it pushes 100psi. :S
A few mates have rb20det pumps and they tend to run around 70psi over 3500-4000rpm.
https://www.sau.com.au/forums/topic/163146-my-rb20-cefiro/#findComment-3027644
Troy,
My car makes pretty good oil pressure. I am puttin gmy electronic gauge back on this week so will know exactly what it runs. As for an ideal i have no idea, al i know is that all the strong and reliable Vic GTRs have bloody high oil pressure when you look at thye factory gauge:)
https://www.sau.com.au/forums/topic/163146-my-rb20-cefiro/#findComment-3027749
Yep those readings were from the stock guage. Which *when* they are working correctly if fairly spot on compared to a mechanical hks guage.
So whats your stock guage read? Stock pump or did you shim the spring?
With Castrol 10w60 oil at high rpm mine sits only just under the 8 on the stock guage, when cold it pushes over 8. too thick. :S
https://www.sau.com.au/forums/topic/163146-my-rb20-cefiro/#findComment-3027761
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
