ant, i like your wheels. look very tough on a dark 33. what are they again? are they rays SE?
Thanks Richard...with the dramas I had getting a set of track rims everything was made better when I bolted them to the car for the first time :P
They are rays RE30....
Hey Roy,
I have just gone thru the same issue as you with spacers and have found a solution.
My front wheels are +42 offset 8" wide with wide case 235 45 series 17" and my tyres were scrubbing on the outside edge on my upper wishbones. So I needed some spacers. I had dodgy slip on ones put on and the steering shake was shocking...
I was in Sydney last week and went to tempe tyres and they made up a set of hubcentric 10mm slip on spacers to suit my wheels.
The best part is they fitted insert shank nuts that go through the wheel and through the spacer and have almost the whole thread holding the wheel on the stud (at least as much as the standard nuts.
the wheels now fit perfectly and no steering shake.
pm me if you would like a photo...
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
    • Set of knee pads for a R34. Will fit every model I think. Comes with everything except the rubber covers for the bolt holes. Still in great condition. You will need to drill holes to mount these or use double sided tape. I can do free shipping and will be shipping from the Netherlands with tracking.
