dont buy the cheapo ebay ones they are shyt.. i had them on my civic and i couldnt see shyt at night unless i was on my high beams... so i just left my high beams on the whole time and ppl flashed my every 30secs... my frined got some for an Audi A3 and they have hight and side adjustements so they should be fine as mine didnt have those but will have to wait till he installs them to see if they are good... but from what i have seen the cheap ebay ones and a waste of time and money... u better of getting a xenon kit...
https://www.sau.com.au/forums/topic/163218-angel-eyes/#findComment-3029366
they aren't supposed to replace your low beam bulbs. they are just a park light that is a ring around your headlight.
you can make them rather easily. all you need is some plastic rods (like the ones that are on house blinds that you twist for opening and closing them) some LEDs, a toaster (or heat gun to heat the rod up to bend it into shape), a hacksaw to score the rod to give the light somewhere to emit from.
there is a site somewhere on the net that shows you how to do it.
https://www.sau.com.au/forums/topic/163218-angel-eyes/#findComment-3030876
thats crazi man where did u get the parts? are the bright enoguh at nite?
at night there not really that bright........they put off a fair bit but its more for an effect and not a purpose if ya get what i mean.....
i bought em as a complete kit from a local wholesaler in adelaide, theyre actual spot lights with an angel ring
more importantly is the lights visible during the day?
yeah where did you get the parts
P.S without the front bumper at night it really looks like a mini cooper :P
looks mean as hell with the bumper, il post a pic........havnt got one at night though, im still in the process of getting some perspex covers made to make it look like i have proper headlights instead of 2 pairs of high powered spotties
https://www.sau.com.au/forums/topic/163218-angel-eyes/#findComment-3031242
Man that looks "FULLY SIC" :)
https://www.sau.com.au/forums/topic/163218-angel-eyes/#findComment-3033507
one of my friends made some up for his soarer using the process mad082 explained. If done well they actually look really good. Although they are only there for looks they don't actually replace your headlights or really even give of any light at all like parkers (the bmw ones etc. obviously do cos their better). I have seen it done also on cars with square headlights and it looks gay, doesn't suit at all. If you have projector headlights (the little round dome type ones inside the headlight assembly) go for it they look awesome!
I like the idea of these custom made headlights, where are you guys buying the spotlights with them already, and got any pics of them out of the car, would be interested to see if a set could be 'incoroporated' into the standard headlight assembly....perhaps with a bit of modification.....
https://www.sau.com.au/forums/topic/163218-angel-eyes/#findComment-3034057
they look so much bigger on a silvia, looks tough though, very aggressive
i did my conversion about 8-9 months ago........wanted something cheaper then constantly replacing genuine headlights......besides its hard trying to be original these days
https://www.sau.com.au/forums/topic/163218-angel-eyes/#findComment-3034608
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
