i was driving tonite and it was raining .. anyways not light rain but not heavy rain either .. sorta in between if i can remember, well maybe a bit less than that .. anyways ... i'm really concentrating on the road cause its raining ... so then i look at the speedo and it says i'm going over 75 ... give or take ... so then i'm thinkin .. shit thats a bit fast especially cause its raining and step of the accelerator... then i look in my rear view mirror then i see a flash ... **** ... anyways there was another car behind me ... a commodore station wagon ... and he got busted 2 ... so there was 2 flashes in like second ... so yeah i'm wondering if these radar detectors work???
https://www.sau.com.au/forums/topic/16322-i-need-a-radar-detecter/
Im pretty sure they do give a indication of police presence... They give u good detection of a camera stuck on the front of a car for both directions and for hte laser I heard that it detects it when it's being pointed on you, so u basically have bugger all time to slow down 2 hte speed limit. If ur goin really fast.. handbrake turn and back the other direction in a hurry!
I was thinkn (cos i tend 2 hav a heavy foot sometimes) goin down 2 rocca's and fittin one of those speed warning things. Dunno what they're worth but it can't be too much
Start at $180 all the way up to $999. The cheaper they are the less warning you get, about 2 seconds from my last cheapy. Pretty useless really. A heap of false alarms to. I would reccomend buying a Bel. You will need to spend at least $400 tho to get any useful sort of warning and minimul false alarms. They work in the same way as the sensor eye in your tv and vcr that picks up your remote. The cheaper Detectors have a internal oscilator that can be picked up by the police radar detector detectors (VG2). They still claim to be undetectable, because when they sense they are being detected they cloak themselves by switching of the internal oscilator. This doesn`t work all of the time as I have experienced( and had my detector taken and been fined for the illegal use of a police detection device). The more expensive Bel brand radar detecters don't have and internal oscilator at all, therefore are totally undetectable.
All Bels are detectable by Stalker detector detector.
If you buy a cheap one, be prepare to pay fine and face confiscation. If you are serious then you need to get expensive one :(
Do a little bit more research and you will see the good one
Originally posted by Miss_Nismo
the whistler ones i have used have never been detected before
Ur whistler has not been detected does not means that it's not detectable. missnismo be careful about using it on the highway. They tend to use stalker on highway patrol cars.
Good luck
Hippy yes the cops do use radar detector detector...more so in VIC and NSW. The latest one is designed in Australia called Stalker. It's been around for a couple of years now and will detect all kind of radar detector. However there is always exception :burnout: just do a search on the net and call around :P
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
