Hey guys i have gone back to university which is kool but sucks at the same time because i have no money to fund my car fetish. So for under 5K i am looking for a base to start a project car so far the best idea i have come up with is a Toyota Cressida, then when i save up source a JZX81 front cut and convert it to a beast, any others ideas would help
Thanks Jamie
https://www.sau.com.au/forums/topic/163226-want-a-project-whislt-at-uni/
sr20 into a mitsubishi sigma or datsun (can buy bolt up kits for the datsuns that have the engine mounts and stuff) or any small car as long as it isn't a gemini or torana
i know a guy with a turbo xf falcon for sale for about 3k. thats in qld, not sure where you are.
Mitsubishi Galant VR4. If you could stretch a little more out of the budget, it would be worth it. Some of those cars have been on there for ages, so you never know what offers they'll take.
http://www.carsales.com.au/used-cars/MITSU...&state_id=0
Get an Na S13 and put a RB30E in it and turbo it like fatz. If I only had 5g to start that's what i would do :happy:
+1 for the s13 idea. for ~1.5k you could have a rolling shell. for another 3k you could have a rb30/25 in there if you play your cards right. you might go over, but a project isnt a project unless you blow your budget.
Sigma Turbo - Rare and in your price range .. Would pump most machines on the rd
it wont take it unless he rebuilds the motor or drops something decent in there.
Thanks Jamie
Cefiro, 1988. You can pick one up for 5k-6k. Then as you earn money, do some work on it as you go...
My mate is doing the same thing, great buy for the package...
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
