Hey guys i have gone back to university which is kool but sucks at the same time because i have no money to fund my car fetish. So for under 5K i am looking for a base to start a project car so far the best idea i have come up with is a Toyota Cressida, then when i save up source a JZX81 front cut and convert it to a beast, any others ideas would help
Thanks Jamie
https://www.sau.com.au/forums/topic/163226-want-a-project-whislt-at-uni/
sr20 into a mitsubishi sigma or datsun (can buy bolt up kits for the datsuns that have the engine mounts and stuff) or any small car as long as it isn't a gemini or torana
i know a guy with a turbo xf falcon for sale for about 3k. thats in qld, not sure where you are.
Mitsubishi Galant VR4. If you could stretch a little more out of the budget, it would be worth it. Some of those cars have been on there for ages, so you never know what offers they'll take.
http://www.carsales.com.au/used-cars/MITSU...&state_id=0
Get an Na S13 and put a RB30E in it and turbo it like fatz. If I only had 5g to start that's what i would do :happy:
+1 for the s13 idea. for ~1.5k you could have a rolling shell. for another 3k you could have a rb30/25 in there if you play your cards right. you might go over, but a project isnt a project unless you blow your budget.
Sigma Turbo - Rare and in your price range .. Would pump most machines on the rd
it wont take it unless he rebuilds the motor or drops something decent in there.
Thanks Jamie
Cefiro, 1988. You can pick one up for 5k-6k. Then as you earn money, do some work on it as you go...
My mate is doing the same thing, great buy for the package...
    • Plazmaman 76mm Pro Series, done. Data to back it up, I posted up somewhere here a few years back
    • So.....wire it up appropriately. You can't use the resister pack with those injectors anyway.
    • that’s the thing i’m on ID1050s and haltech not getting power due to the injector resistor
    • ahh okay cheers, i was thinking of just going for the m073, think m079 would be way too overkill considering they are same size.
    • My first car was a HG. I'm very familiar with them. A mild cam upgrade is a good idea. The 186 is a very flexible engine - meaning it has good torque from down low. You can give up a little torque down low for quite a lot more excitement in the mid range, and a bit more up top - but they are not exactly a rev monster. You need to upgrade valve springs at the minimum. For a bigger cam, you'd want to make sure it wasn't still running the original fibre cam gear. That would be unlikely, given that most of them shat themselves in the 70s and 80s, but still within the realms of possibility. Metal cam gear required. Carbies are a huge issue. The classic upgrade was always a Holley 350, which works, but is usually pretty bad for fuel consumption. The 186S had a 2 barrel Stromberg on it that was very similar to the one on the 253, and is a reasonable thing if you can find one, and find someone to help you get it set up (which is the same issue with setting up a 350 to work nice). The more classic upgrade was twin sidedraught CD type carbs, or triples of same, or triple Webers. The XU-1 triple Webers being the best example. You can still buy all this stuff new, I think, but it's a lot of coin to drop. And then the people able to set them up are getting fewer and further in between. There's still some, but it used to be everyone's** dad and uncle could do it. **Not everyone's! But a lot. All in all, I wouldn't get too carried away with the engine. Anything you do to it without a full rebuild for power and revs will only make it slightly faster. I am all in favour of a complete teardown rebuild, with nice rods and pistons, 10 or 10.5:1 compression, and a clean port job with at least a big enough cam to run 98 with that compression, if not bigger. And if I did that to a dirty old red motor, I'd want to inject it too, which I'd struggle to fight against the devil on my shoulder that would argue for ITBs and trumpets. But the bills would start to mount up, and it will still never make stupid power. OK, a few people still know how to build absolutely mental red motors, courtesy of the work that went into HQ racing and modern knowledge being applied. But even a 300HP red motor is no match for an RB20 with a TD06. So you have to decide what it's worth to you. I'd just put a set of 6>2>1 extractors, a 2.5" exhaust and an electronic ignition conversion/dizzy on it and just run the old girl like the fairly slow old girl that she really is.
