Selling my 1986 Corona which i purchased recently as a runaround car while i was deciding what car to buy for my project.
Well, i have found a car which i would like to purchase so i need to sell this car first.
The car is in very good condition throughout, no rust or damage.
I have all the reciepts and log books for the car.
100% reliable, will start first time every time and run perfectly, no problems with car at all.
The car is manual and is fantastic on fuel.
Just had the car serviced and tuned.
It has : 3 1/2 months rego, exhaust, K+N Filter, full alarm, new radiator, hoses, lifters, brakes and carby (all with reciepts), 4 speaker radio/cassette.
Looking for $1200.
What more could you ask for in a $1200 car ??
Contact me here or at [email protected]
I'm in Sydney.
Thanks for your support INASNT.
Maybe your cousins Corona isn't in as good condition as my one or maybe it hasn't got as many features.
If i don't sell it, i'll keep it, it's the perfect runaround car, nothing wrong with it.
Guest INASNT
if u were in mebourne u could have come pick it up ad used it for spare parts
    • Gosh these Rb pulleys/alternator or whatever is causing the problem is absolute rubbish lol. Haven't even done that many km on it.
    • Yeah man, will only progress further hopefully. The bonnet is coming off to get sprayed very soon
    • Once the belt slips it can very easily cause a cascade that encourages more belt slip. Check the pulleys carefully and see if the grooves have cupped. If it has it's time to replace the pulleys. If the rubber has glazed you also need to replace it. Shouldn't be shiny. From the factory there's a lot of exposed fibers(?) on a v-belt that will go away as it's broken in but some should still remain visible without sticking out significantly like a new belt. I went through this on my dad's Camry recently. It would keep slipping even after setting the tension higher, only solution was a new belt.
    • Belt polished and/or pulley(s) glazed. Rub pulleys with sandpaper, replace belt.
    • I've also got a quick jack. I would never get under my car again without using it.  While it might be quicker to use a jack and stands, it is such a quality of life improvement that I wouldn't have it any other way now.  How much slower the quick jack is to setup will be based on your circumstances. Can you leave the jack rails on each side of the garage? Can you leave the hydraulic lines attached? etc.  If you can drive the car into the garage and simply push the jacking rail thingos under the car into place, it is super quick to setup and use. But if you have to pull the pump unit out of storage, attach the hydraulic lines, wheel out the lifting rail thingos.... yeah takes a bit of time. Having said that, I would still prefer that to using a jack and stands lol.
