Guys lets not muck around, if you think you can get these parts cheaper then go ahead and get them. there is a little play in the prices but simply if you want more items the easier for me to cut down the prices.
Trust T517z 8.0cm turbos X2 $2500 the pair, (may seperate)
Trust front and dump pipes to suit turbos $800
Custom Top pipe (Polished) with air splitter fitted to stop air flow colliding $250
Excedy Heavy Duty Single plate clutch from R32 GTR $400 pick up only, travelled roughly 20,000kms wouldnt recommend for applications making more than 300RWKW. will try get some pics up tomorrow
if you want pics ask otherwise refer to previous post.
still selling stuff mate, good luck.
im trying to get the cash up asap so i can buy stuff off ya!
just quickly, what kind of power can you see out of them turbos when the car is set up right?
cheers mate
Edited by Turbz_13
cheers mate
hey turbz, not gonna throw to many numbers around but, mayby 350-360 rwkw on pump and 400+ on c16. :) happy easter too.
ok just one? umm well depending where you are and what your offering id probably be chasing $1400, as its gonna be alot harder to move the one left over.
sorry if its a headache. let me know
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
