Do Stageas have automatic fold-back mirrors, like Mitsubishi FTOs, and some other imports? I thought it was a standard option, but in all the photos on here I haven't seen any folded back ;) If they do have the option, is it on series 1 and 2?
Cheers,
David
Edited by DaveB
https://www.sau.com.au/forums/topic/163305-foldaway-mirrors/
Yep, I haven't seen an import without them either. Most aussie cars have them too, but their not electric.
I think in Japan they are pretty much a nessecity due to the parking situtation over there.
from what ive been told by Japanese nationals
Its mainly for bike riders and scooter riders...so if htey hit a mirror it iwll fold out of the way, and not create as much injury.
Its a requirement that all Japan cars have at least folding mirrors, but ive only see 3 or 4 older cars without electronic mirrors...My series one has them....i never use them though
i just always forget about it
im going to rig a switch to make it close when i turn the ignition off...just gotta get int ehre with a multimeter to figure it out
they do close when you turn your ignition off, you just push your switch to retract.
Hook them up to a turbo timer as well as the windows and sunroofs, when the car switches off it closes the windows one by one then the sunnies and finally the mirrors fold in! Would be a great party trick but you would waste a lot of time standing around waiting to make sure it all happened before you left the car in the parking lot.
Grant do you live on base? If not where do you park/work on your car? I know you need to have proof of a parking space to be able to register a car in Japan (in the cities anyway)
Cheers
Luke
LOLOLOL i can't believe i did that!!!!
Yeha, but i forget to always hit that button
remember im a turbo timer kinda guy (even though i dont have one lol)
Hey Yoko, lucky you didn't put an a instead of a u. PMLOL.
Saw a numberplate recently......041 GAY.Fark, it pays to advertise.
i use my for aerodynamics :happy: go fast = tuck the mirrors in :huh: have used them once to help a bike get through....
thats my favourite trick, flick the switch as soon as you plant it away from the lights.
cracks my kids up every time. :)
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
    • https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.  Discounted tickets 20% off for their various tickets until the 3rd of Feb Monday. Drags, show and shine etc.  I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.  I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.  https://gtrfestival.com.au
    • Does have series 2 airbag steering wheel and passenger side airbag also.
    • Do I have a series 2 or has someone spent money to have a series 1/1.5 look like a series 2? Everything I have read says the series 2 came out in 1996. I have a car manufactured in December 1995. The exterior, engine and interior are all series 2 other than the dash facia is series 1. Paint code is also kr4 that I believe is only available on a series 2. I have a VX Vehicle History Report and it says Grade: GTS25T TYPE M2 Manufacture date: 1995-12 Make: NISSAN Model: SKYLINE Body: E-ECR33 Grade: GTS25T TYPE M2 Engine: RB25DET Drive: 2WD Transmission: F5
    • I went to Repco to get them to test the battery using their tester (not a volt meter), alternator shows 14.3v when running, and when the car was off after the it was on full load I think it was 12.6v but the guy said it was all good. Terminals are all clean, no corrosion. Though I coulda sworn when I tightened up my alternator belt the car idles a bit higher and the steering wheel shakes a bit until it's warmed up. I wanted to confirm for the earth cable/s, are you referring to the 2 wires that are bolted onto the frame rail under the battery? I might be overthinking this a bit.
