HI guys
I have a Serie 1.5 R33 GTST, and ever since i installed the new clutch, i have notice the backlash in the diff bad, due to the harshnes of the clutch.
Can somone point me to how, or if it is possible, to adjust the backlash on the diff?
I have read the DIY's but there is nothing there.
Do i need to take the whole diff out? Or can it be done on the car?
Any help would be greatly appriciated.
Edited by WogsRus
I can do all that, i race all the time, not in that car.
What i am refearing to is driving slowly through town, in second, when off/on gas, you can feel the backlash in the diff, the slack in the pinion and backlash.
That is what i want to cure.
diff bushes, where are they, do you mean the pinaples or something else. The diff doesn't wine at all, not a bit.
Basically if move the drive shaft, the diff stangs still, and you can rotate the shaft 0.5-1cm before it meets any resistance. It's not in the drive shafts as far as i can tell.
So i am wandering if there is any way to fix this.
From my fiddlings I've noticed 2 sorts of 'slack' that feel similiar to backlash in the VLSD's.
There's backlash its self.. Which whines like crap and then there's slack inside the diff center.
Then there's the slackness that comes from the diffs spider gear to center engagement.
When removing the spider gears there's (from memory) 4 or 5 lugs that lock in to the diff center that provides drive to the half shaft splines. From what I've seen these can be a tad sloppy and cause a slack ness of sorts.
With the diff out of the car and backing plate off; turn the half shafts, you can feel/see the slackness within the center as the axles move yet the diff center doesn't. You can also hear the slackness coming from the diff spider gear engagements. Now turn the input (tail shaft) and you will see there's no backlash. Hold the half shafts while turning the input and again you'll see there's no backlash but slackness 'inside' the vlsd center.
TO4GTR is right.. From what I've seen excessive backlash does = a noisy diff.
the bushes are on the rear diff cover in the subframe. 2 round ones just above the hicas rack.
easy way to tell is under power lift off the throttle and it should thud from the back.
mine were that gonbe that i didnt have to undo the botlts at all. it just dropped out lol
  • 1 year later...
well does anyone have a solution for the actual whining backlash ?
i have this and need it fixed if possible if someone could guide me along :laugh:
cheers
Looks likea reshim is required from my internets searching - this sound correct?
You would be correct :D
There is a shim either side of the center. You put a thinner one on one side and a thicker one on the other.
The measurements part i don't know which is why mine will go to a specialist one day soon to be done.
  • 4 years later...
Revived this thread to see if anyone has some answers to my question.
I have an r33 S1 and my diff has been making a thud and squeek as you throttle on and throttle off. I jacked the car up and the tail shaft has the same thing with about 1cm or so of play.
When moving the tail shaft you can actually see the parts move coming out of the diff to each wheel. This is with the handbrake on
I pulled my diff out and now am trying to work out what I should actually be doing with it.
Someone has quoted me $150 + a case of jimmy to do a rebuild but im waiting on details from him to actually know what his rebuild involves
Any help would be appreciated
those are the cv shafts.
with the hanbrake on, you should get very little movement from them.
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
