Hello Every one,
Some of you might know i am from the USA
I have a S13 coupe (240sx with silvia convertion)
And a S1 RB25DET
Right now I am trying to figure out this boost issue,
Where it creates boost at a stand still.
A lot of ppl say this shouldn't happen.
but some say it can.
In the FSM it say's 0* is the first mark to the left (left - to - right)
and that 15* would be the forth mark
But when set to that mark, it does not idle/rev up normal
So..when I set it starting from the mark on the right (right - to - left)
The car idles, and revs normal, and its very responsive
and doesn't hesitate like when at the other mark
but still creates boost....
Its driving me crazy, but i hope the engine timing isnt off.
And its just the ignition timing.
_________________________________________________
VIDEO !!!!!
Here you can see the boost @ a stand still.
3in downpipe stright into my 5zigen catback (no cat)
With a TurboXS RFL Blow off valve
th_MOV04671.jpg[/b]
After playing with the timing, it still makes full boost.
Any ideas to what the issue is, or is this normal
Edited by tomtomtuning
https://www.sau.com.au/forums/topic/163315-rb25det-making-boost-when-reving/
Here is a picture of the motor in the car
Car Facts
S1 RB25DET
Greddy Intake manifold
Q45 throttle body
TurboXS Blow Off Valve
Front Mount Intercooler
2 1/2in Hot side (intercooler piping diameter)
3in Cold Side (intercooler piping diameter)
Walbro 255 lph Fuel pump
Z32 Fuel Filter
Stock Turbo
Custom 3in Downpipe (No Catalytic Converter)
5zigen Catback exhauist
does the car rev up really slowly now? is it really gutless?
if it is, you have a major timing issue. your timing belt may have jumped a tooth, or your crank angle sensor may be shagged, or worse case scenario (and this happened to a mate of mine a few weeks back) you have a broken cam.
what the fcuck. That is near imposible unless your timing is stuffed.
Does the car drive well? aldo how tight is your spring setup in the BOV, maybe the vacume line for that is not connected properly, but techincally these is no way a turbo can make that boost at no load????
also on a side note, i would lose the 3" cooler piping on the cold side. go back to 2.5". the fact is that cold air is denser, so that once it comes out of the cooler it takes up less space than it did when it was hot, so you would be better off with 3" on the hot side and 2.5" on the cold side.
  Quote
unless you have an anti-lag system.
but my guess is 1 of the 3 things i said before. on my mates car he would make 15psi by reving the car on the spot. that was on a ca18. it would accelerate really slow (and just sitting on the spot it would rev up really slow like the timing was really retarded). we just thought the timing belt had jumped a tooth as it was overdue for a new belt, untill we took the rocker cover off and the cam was snapped near where it goes into the crank angle sensor. it still had enough pressure to spin the cas, but not all the time.
In the video you can tell (sort of) how fast it rev's up
When i set the timing to the marks on the right, it was real responsive.
but in the factory service manual, it stats that 0* is the first mark on the left.
My car seems 0* is the first mark on the right.
Can any one confirm for me, what TDC is on the crank pulley?
The car is on jack stands, i am doing the brake upgrade right now.
but tomorrow i will try to drive the car some, to see how it is.
All the vacuum lines are fine, i double checked all that
The intercooler piping will be changed sooner or later.
I am going to drive the car the way it is.. for this summer
And i am building another RB25 block/head, and will be installing the built motor in the fall.
So a better much more efficient intercooler and piping will be installed then
I Plan on checking the ignition timing again (CAS)
And if i can not figure this out, then i will have to pull the belt cover
And try to take a look at the engine timing.
I might also pull the rocker/valve cover to take a look at the cam's too
by the look of the video, i think it may be just a dodgy gauge. it doesn't actually sound like it is spooling, and it jumps up very quick. my mates car you could hear the turbo spool. does one of your mates have a gause you could borrow?
where does they gauge read from?
  Cubes said:
Not sure.. To me it sounds a little dead just before it starts making boost.
like buuuuuuuuuuuuuuuuuuRUMMM
Maybe I'm used to the 3ltr and how it tends to rev a bit quicker?!?
mine goes.. bruuRUMMM
lol
The video was taken when the timing was off. before i begin adjusting it.
I will make another video tomorrow. showing how it rev's faster and smoother now.
And again, can some one confirm for me which mark on the crank pulley is 0* ?
is it the one all the way to the left, or the right.....
The stock timing should be st at 15* at engine idle of 650RPM
Its a brand new AutoMeter Boost gauge....But there is always possiable it could be bad.
I will see if my buddy has another gauge.
It is connected to the Intake manifold, runs though the fire wall and to my dash
I used a crappy digital camera to record the video, so the sound might not be the best.
More videos to come tomorrow.
  WogsRus said:
the ZERO point is the yellow marer on the pulley. Esentially if the light is on the pulley, the ZERo mark is the first mark form top, so it goes 0 5 10 15 20 25 30
Thats what it shows in the FSM....
But when ever i set it to 15 (starting from the first left mark)
The car seems really rough.
I guess the engin timing is that off?????
I might as well just remove the belt cover and take a look at the timing marks on the cam
To see if that is off.
  mad082 said:
mine would make small amounts of boost if you just floored it (spike up to maybe 5psi) but wouldn't go to full boost.
Yes, that i have heard about. i have had 2 SR20's before and that is what they did.. small amount of boost. but not full boost.
Tomorrow the first thing i am going to do is pull the fornt cover and see if i can tell if the timing is off on the cam gears.
And if they are.. then it looks like ill be doing some work to re adjust it....
I will update you tomorrow with what i find, and the out come.
THANKS to every one !!!!!
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
