Hey guys,
After months of intermittent flickering/bouncing of my tacho needle....its seems as though my tacho has finally had enough and wont run past 2000rpm any more!
I've read the DIY guide by 'pushead' on removing the instrumentation cluster and it seems to be fairly easy.....btw awsome guide (lots of detail an great pics)...cheers.
I still have a few question though -
1) The guide finishes with the cluster coming out of the dash, but still connected.....what happens next? Are the wires running to the cluster - soldered? or do they use connnectors?
2) When replacing the cluster, do you need to calibrate it? How do u go about this calibration proceedure?
3) Does anyone know where i can buy a 'new' cluster? or can u only buy 2nd hand ones? How much am i expecting to pay?
4) Do you know of any instrumentation experts where i can get the work done? How much roughly am i looking at? (I dont know if i will do the work myself or not? It depends on how much stuffing around is involved and how cheap it is - to simply get the work done by someone else.)
Cheers,
:P
https://www.sau.com.au/forums/topic/163320-r33-instrumentation-cluster/
Hey guys,
Cheers,
:P
To answer your questions in order...
1) The wires to the cluster use connectors - just need to pop them out
2) I didn't calibrate my speedo when I installed my Nismo dash, but i did do some sanity checks - i.e checked the speed displayed on the speedo against the speed readout on my PFC and also got my g/f to drive next to my car and compared my speedo with the speed her car was displaying at 60, 80 and 100km/h. My speedo was pretty much spot on (give or take), so didn't bother calibrating, although I would've done so if it was substantially out.
3) I doubt that you'll be able to get a new dash cluster, although if they were available, then a Nissan dealer would be the best bet (they may be able to order in). If you're after a second hand dash, I have one in perfect working condition that came out of my S2 R33 that I'd sell for $150 (plus postage).
4) Replacing the dash is pretty easy - the DIY guide is excellent and you should be able to do it yourself without any problems, so you shouldn't need to pay anyone to do it for you.
Cheers :happy:
If you pull the cluster apart its possible to find whats wrong with it.
There could be a few 'dry' connections where the female connector is connected to the circuit board. you can tell this by looking at them and if the solder looks as if it has been broken.
This happened a to my pulsar when I had it. Just had re-solder those connections and bob's your aunty.
You might have a different problem though.
ps. why was this posted in the DIY section aswell?
cheers guys :huh:
i think ill take a look at it myself first...see if i can work out why its playing up, then go from there.
p.s. im not sure why this post appears in the DIY section as well - the first time i tried to post it, i accidently posted it in the DIY section and a message came up saying i couldnt post it in that section (the post was cancelled!) So i decided to post it here instead . Now its appearing in both??? I dunno? :happy:
It appears as though i have lost my copy of the DIY guide pushead posted about removing the instrumentation cluster!
Ive searched though the entire forum and cant seem to find a link that works (there is a DIY post with a link to pusheads guide - but the link doesnt work!) :)
Just wondering if anyone could re-post or re-link the guide....it would come in very handy, as i was planning on having a play with it tommorrow.
Cheers,
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
