Hi
i recently purchased some sony 4 way 420w 6x9 speakers for $74 and i am wanting to put them in the rear parcel shelf of my r32, i noticed that the hole in the wooden parcel shelf fits 6"speakers and same with the hole in the metal underneath, but i dont want to cut up my metal parcel shelf to install the 6x9s. Anyone done this b4 without cutting the metal hole bigger??, i am thinking of spacers but i am still quite confused as i have only had the car for 2 weeks and i dont want to screw it up yet.
I have looked everywhere on this site but i can only find topics of people making a new thicker parcel shelf on r33's.
Images welcome of 6x9 rear parcel installs
Gday mate,
You can buy the spacers from Strathfield/ JB pretty much any "hi fi" store but the thing is to get spacers that allow the speaker magnets to pass through the holes in the parcel shelf ;)
I was going to go down this route, but i ended up getting a set of JBL 6.5" for the rear, simply cauz its a bit of a hastle with the 6 x 9" but everyone to their own eh :)
You mentioned that you only just got the car? Well then I’m guessing your a bit hesitant pulling up the seats etc... If you pop over to the DIY section i have made a thread explaining how to install a sub in a 32, in there you can get an idea of the best way to get the rear seat out etc :)
Anywayz, have a great Easter mate, and enjoy ya tunes!!!
Regards,
Sean'O
Here is the link: http://www.skylinesaustralia.com/forums/in...&hl=install
running quite low on money lol, so im gonna make some spacers out of mdf, put the speakers in the spacer and bolt through the speaker, spacer, wooden parcel shelf and into the metal parcel shelf.
If anyone has some pics of their own 6x9 rear install could they post up pics and info on how they did it?
Thanx
Dont worry peeps, i am going to cut into the parcel shelf with the help from my brother who has done it on past nissans.
I will take fotos and hopefully make a diy tutorial out of it, to help everyone else with this problem.
thanks anyway
thanks anyway
cutting the metal of the parcel shelf is a defect. If a cop catches you, might have some trouble fixing it back up....
Couldnt agree more, cutting the parcel shelf is considered a defect because I think its considered a major structural part of the car or something like that
Yep thats correct :), not worth it mate !!!!
Regards,
Sean
  • 3 weeks later...
man just jump in the boot with a small die grinder and cut away. no cop will check. if a cop pulled u over im sure he will be more interested wat u have under the hood other than ur system.
what ive done
made new shelf from MDF
got spacers for 6x9s and screwed it all together
cant see the speakers because they are behind the seat cushon and my window tint is dark so dont care how they look either
You can cut the parcel shelf.
Provided....
You dont cut within 50mm of child seat restraint bolts.
and
You only cut the minimun amount required to fit the speakers in.
Even after telling customers that its not advisable to do so, and trying to talk them into buyin speakers that will fit, but we will still cut them if a customer wont be swayed.
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
