Hey all.
Just a quick run down. I have an r32 GTR when I originally got it it was a bit of a slug so I took it to a certain workshop best not to mention. to see if they could tell me what was wrong with it........ well, a set of turbo's (which they told me were 420h when infact were 320), power fc (with an incompatable hand controller) a tune (that made 192kw at all 4 on 18psi) and a 6k bill at the end of it. the engine started knocking 2 days later, but that is another story.
So i ended buying another rb26 (5k) , engine seems tidy supposable about 60'000k's since a rebuild. I swapped all parts over and is in the car now did compression test I cannot remember exactly what it got but it was fine. but now after another mechanic has tuned it it is only getting 220kw at rw with the following mods at 14psi.
- pods
- cam gears
- garret 2860r (small ones)
- split dump's and full 3" exhaust
- Power FC
- apexi AVC-R
Thats all i can think of at the moment. That is not normal is it? just after some opinions and maybe some suggestions.
The engine wasnt leaning out just wouldent go any harder. Even the mechanic said he was expecting alot more from it.
cheers guys
https://www.sau.com.au/forums/topic/163381-power-issues/
Dynos are for tuning tools mainly, figures can vary alot aswell, plus have you got a dyno graph preferably with afr curve on it this could be a problem not smooth? what are the cam gears set at? did he change anything? so many questions so thats a start
https://www.sau.com.au/forums/topic/163381-power-issues/#findComment-3032497
He has a GTR, it already has a decent FMIC.
14psi 220rwkw = shit... thats if the dyno is on the ball.
It should really be up around 250-260rwkw or there abouts
The turbos you have, with around 20-22psi should see you around 330rwkw.
Its time to find another tuner.
Cheers.
https://www.sau.com.au/forums/topic/163381-power-issues/#findComment-3032625
dyno plot please
we need to see power and AFR
also what about fuel pressure
and boost pressure
they would help
Agree with everyone else here - I have an R32 GTR with similar mods seeing 280awkw @ 18psi
have not seen any mention of mods to fuel - fuel pump and fuel pressure regulator ?
what's a std pump and fuel mixture going to deliver ?
https://www.sau.com.au/forums/topic/163381-power-issues/#findComment-3032668
Firstly thanks heaps for the reply's I am not as honed into the tuning side of cars as I would like to be, but I will tell you as much as I can.
- The tune was done about 1 month ago and they tuner's printer was stuffed something along those lines, I couldent get a print out. He showed me the results on screen. They were sharp curves and smooth all the way to 220kw then it was like they hit a wall. He said he coudlent sus it out, I am not sure if that is any kind of indication at all.
- Its only got a stock fuel pump but wasnt showing any signs of leaning out at all, he he stuck a gauge on to check the pressure and said there was heaps.
- He did advance the exhaust cam a little I am not sure exactly how much but he said it made a bit of a difference.
- It has got a factory frount mount but I assumed that would be ok for a bit more power than this, but I am far from an expert.
The car is in a few pieces at the moment with me trying to clean everything up and looking for any leaks or anything a bit dodgy. It should be all back together by then end of the weekend so I will try and get the dyno print out if he has it, otherwise I'll get another dyno.
Also whilst this has all been going on I moved to darwin right after the engine was put in. (truck drivers stole my audiobahn amp, and my tyres bald as bald when the car got here, again another story) so air temp is like 32 deg all day, and there is a vast lack of tuners and dyno's around!
https://www.sau.com.au/forums/topic/163381-power-issues/#findComment-3032852
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
