I think Col is looking at doing another one early in winter...at least that was the news a few months back
Tis June Arhhhhh :)
May has too many motorsport events already and there is something on every weekend so June is more suitable for everyone me thinks...
https://www.sau.com.au/forums/topic/163397-dyno-day/#findComment-3033401
There is only going to be 25 spots so it will be a case of first paid, no cut off date...
And before anyone asks, yes it will be a 4wd Dyno Dynamics dyno so the GTR's will be able to run 4 wheel figures...
good to hear its going to be on a proper dyno this time :sick:
https://www.sau.com.au/forums/topic/163397-dyno-day/#findComment-3033994
What happened to the dynoday that was supposed to be a Godzilla Motorsports? Hope one can be held there in the near future
That was not an SAU event, they just posted it up on the forum and got limited responce so they canceled it
I have approached Godzilla, more to come on this...
https://www.sau.com.au/forums/topic/163397-dyno-day/#findComment-3035914
I have approached Godzilla but the responce was not positive as there are other issues/politics clouding the situation which I dont want to get into with them as it has nothing to do with me. Plus I was snobbed at the mini jam by the driver of their black GTR so Im dis-interested in bothering in contacting them ever again... :yes:
oh bugger :P i was looking forward to having a dynoday there...
https://www.sau.com.au/forums/topic/163397-dyno-day/#findComment-3036987
they have a 4wd dyno dynamics dyno.
They are on my list...
We will see who offers the best package and then go with the best offer...
Im aiming for a Thursday night event again, hence the name "Annual Dyno Night" however noise restricitions puts allot of workshops out of the running...
I have one confirmed atm, but am still searching for a better offer first... The event details will be up by late April giving 7 or so weeks notice... :yes:
https://www.sau.com.au/forums/topic/163397-dyno-day/#findComment-3037025
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
