R32 custom kick panels for speakers?
Guest scourge
Hey guys, first post at this Skyline board, but I am a member at a few others. I own an R32 GTS-4 and I want to put speakers in the lower part of the door and I want to improve my front stage. In the USA, you can get prefabricated custom kick panels to fit your car. You just install your speakers, run the wires and then install the pods in your car on the floorboard. Its a real easy install.
But, my tiny island has no shop that can do custom work and I want kick panels for a 4 inch midrage and tweeter. I want to put a mid bass in the door. Anyone have custom kick panels in their R32 Skylines?
https://www.sau.com.au/forums/topic/16341-r32-custom-kick-panels-for-speakers/
I posted a similar thread here a few months ago and didn't get a reply. I've done a bit of checking by looking at speaker options and by removing the kick panels to see how much room is available. There is a lot more room around the pedals in american cars as they are left-hand drive so it's not as easy in right-hand drive cars. Because there is very little spare room behind the kickpanels I decided my best option was to use a 2.5"-3" dome midrange with a sealed back-chamber such as Dynaudio MD140-2s or Morel MR55s and a tweeter in the kick panels as they dont need any space behind them and dont need to sealed to avoid back-wave cancellation. These speakers are quite expensive but by the time you factor in the savings of a simpler installation they will pay for the difference in price themselves.
yea kick panels are a bit of a problem...all i would do is use the 6" factory mounts that are in the door(it looks stock but it works) and then for the sound stage quality prob...line the tweeter up with your head...i.e.on the reverse side of the mirrors, or, they can be neatly mounted it the door (by someone who knows a bit about cutting into doors)
its a bit of an effort but sounds great
    • I thought about ditching it but I was worried my bonnet would sound like a 90's Swift GTi sub-filled boot.
    • Have you found that you have to tighten your alternator belt once in a while? Mine has started to squeal again after the mechanic tightened it roughly a year ago and the engine starts up slow if I don't start it every day (think the starter motor is going out). It used to be if I don't drive it once a week I'd get a quick squeal on the belt but now it's every day or every other day. I might make a post of the start up sound.
    • I spent the entire of the long weekend going through my garage and I'm now, after 3.5yrs in this house, able to fit a car in. The garage is quite long and the back half has a high enough ceiling for a 2 post lift but it's going to just take too much space and I don't think I'd be able to get around the car if it was in the air. So, in comes the quick lift. It looks perfect. High enough to do most things, I reckon even getting a gearbox out would be doable.  Does anybody here have one? They're fairly cheap (~$3k) considering...  https://www.dtmtrading.com.au/product/quick-lift-portable-vehicle-hoist-3500-kg-worksafe-approved/ I'm also a bit of a non risk taker so I'd probably still use stands when under!
    • Well now we all see it! I did the same. Then cut it out. Then melted half of it. Then discarded it entirely. So... you're in good company.
    • I just replaced the god awful, sagging, crunchy bonnet insulation. It's something nobody but I see but it's been at me for a while.
