Current Skylines Australia Nsw Members
Shell
Hey guys n gals,
Ill be direct depositing the 60 into the account this morning and faxing my forms over.
Can someone please pm me when it all comes through to confirm?
And when you send out the package to me, could I please have a receipt too??
Cheers,
Chris
you can now add me to the list :D
Receipt Number: N00097394
Date: 09/08/2006
Time: 8:50 AM AEST
Transfer From: Savings xxxxxxxxxx71
Transfer To: Skylines Australia NSW
BSB: 082356
Account Number: 546393766
Customer Reference: evil_weevil membership
Amount: $60.00
Transfer Made By: Chris Quick
Important Information:
Please allow at least two working days for the transfer to be received
Thank you for using Internet Banking
done and done - Ill fax my forms now - :(
And still - a receipt will be great thanks!
cheers,
Chris
p.s. Faxed Sent :) awaiting confirmation :D
Edited by evil_weevil
Id check for you now, but it wont have been cleared yet
By the time the paperwork gets to Shell (damn she's good to us!) the money should've cleared though
Hey guys,
I have just made an internet transfer for $65.00 for membership and I am faxing through the forms right now along with a copy of the receipt from the transfer.
Cheers,
Anna :)
Hey guys,
Cheers,
Anna :)
Oh yeah, what happens now! How long does it take to get processed?
Cheers
Quick question - how long till I recieve my goods in the mail?
I really need to get my CAMS licence cause I want to do the track day on the 1st september - is there anyway I can still apply asap??
Cheers,
Chris
Hey Chris you can apply for the CAMS license straight away, just put SAU on as your club. They then send the license out.
Your club membership card and license are checked at each event, not when you apply for the license :D
Hey guys,
Paid my fee and faxed through all last Tuesday. Should this be up and running shortly? Really want to access some of the members only areas!
Cheers
Anna
    • It depends on what the guy who bought its Ratio is. Mine is a 4.36 Jus Jap told me anything above a 3:9 has equal length shafts which the Nismo center's shafts were not.
    • If those shafts in the last 2 photos are the ones that came with the diff, you have no hope of fitting the other ones because they are completely different
    • I have recently fitted a Nismo GT Pro Center second Hand buy still in the box i got stubs with it but they are 5 bolt and I need 6 (3x2) I was told by Just Jap that for a 4:36 ratio the stub axles are equal length sku 38220-0V161. They didn't have any in stock but I picked up the ones pictured. The one with 5 bolt are the ones that came with the LSD. The right side went in no issues but the right....I have happened the fk out of it put it in a press and it still sticks out about 5mm too far. It was sticking out about 25mm but after bashing it like Chris Brown did to Rhianna I managed to get it a bit further in but seems stuck again now. Any ideas? Should I just leave it 5mm out and send it?
    • Meh. I "see" a typo above, that should have been "sell".
    • The clutch pedal has a procedure for adjustment. This can only be done after you are 100% sure the system is absolutely free of air bubbles. You must bleed the clutch master cylinder first, then the "separation pipe" which is the clutch damper line, then the operating cylinder as detailed in the service manual. Also, you must fully depress the clutch pedal between shifts. Just because you can't feel it grabbing does not mean the input shaft is truly decoupled from the crank. At high RPM clutch plates are vibrating and moving around, you need to give it the best possible chance of success. On the BCNR33 Nissan revises these adjustment procedures slightly but not by much: I would be careful with trying to play games with these adjustments. As for the Nismo operating cylinder they say a lot of things. In practice the twin plate clutch needs less movement on the clutch fork to disengage because the whole stackup of the flywheel + friction plates + pressure plate is much taller. Personally if you find that the clutch still disengages too high at the top of the travel I would try the Nismo operating cylinder. Make sure to follow the air bleed procedures.
