Current Skylines Australia Nsw Members
Shell
  • 3 weeks later...
yes, hurry up or i'll take your little bar away again :P:unsure:
Hi Shell,
Ive just faxed over the application form and transfered the money online. Hope you guys receive them soon.
Cheers
Jason
  • 3 weeks later...
I sent the payment and faxed the application form yesterday.
I look forward to joining the club.
cheers,
Andrew
edit: I think the fax went through upside down. Damn the new fax; technology has got me again. :huh: Well at least the payment went through. lol
Edited by padey
Hi,
I sent my application via fax and paid on 27/04.
Seems like a really good club, can't wait to meet you guys.
Thanks
Edited by G3TFKD
Hey Shell,
I sent my paperwork and money off a while ago, still haven't received anything in the mail :rant: just an update to know that nothing has gone wrong would be nice :)
    • It depends on what the guy who bought its Ratio is. Mine is a 4.36 Jus Jap told me anything above a 3:9 has equal length shafts which the Nismo center's shafts were not.
    • If those shafts in the last 2 photos are the ones that came with the diff, you have no hope of fitting the other ones because they are completely different
    • I have recently fitted a Nismo GT Pro Center second Hand buy still in the box i got stubs with it but they are 5 bolt and I need 6 (3x2) I was told by Just Jap that for a 4:36 ratio the stub axles are equal length sku 38220-0V161. They didn't have any in stock but I picked up the ones pictured. The one with 5 bolt are the ones that came with the LSD. The right side went in no issues but the right....I have happened the fk out of it put it in a press and it still sticks out about 5mm too far. It was sticking out about 25mm but after bashing it like Chris Brown did to Rhianna I managed to get it a bit further in but seems stuck again now. Any ideas? Should I just leave it 5mm out and send it?
    • Meh. I "see" a typo above, that should have been "sell".
    • The clutch pedal has a procedure for adjustment. This can only be done after you are 100% sure the system is absolutely free of air bubbles. You must bleed the clutch master cylinder first, then the "separation pipe" which is the clutch damper line, then the operating cylinder as detailed in the service manual. Also, you must fully depress the clutch pedal between shifts. Just because you can't feel it grabbing does not mean the input shaft is truly decoupled from the crank. At high RPM clutch plates are vibrating and moving around, you need to give it the best possible chance of success. On the BCNR33 Nissan revises these adjustment procedures slightly but not by much: I would be careful with trying to play games with these adjustments. As for the Nismo operating cylinder they say a lot of things. In practice the twin plate clutch needs less movement on the clutch fork to disengage because the whole stackup of the flywheel + friction plates + pressure plate is much taller. Personally if you find that the clutch still disengages too high at the top of the travel I would try the Nismo operating cylinder. Make sure to follow the air bleed procedures.
