Hi Shell, I'm just wondering when is SAU going to send my parcel with stickers that I've ordered it's been now like three weeks??? Please follow up and give ETA. :P
Thanks
dave
Hi Shell,
Just a quick question.. when I joined I got the extra card for Steve and now he has joined the forums as well. Who do I have to ask to get the little blue "NSW Club Member" bar under his user name so he can access the extra members area as well?
BTW his user name is plumba
hi shell
i send my membership papers off on tuesday, whats the turn around on getting the membership card and all that? just asking cause i wanna get my CAMS asap
thanx
Hi mate, I assume you posted it? I haven't seen it on the fax machine.
Anyway, you can apply for a CAMS license before you get a card, but you will need the card when you go to an event that needs the license.
If you don't have the card before you want to do an event we can fax confirmation of your membership to the event organisers
Picking up stickers I've been waiting on today, so yours and everyone else whose been waiting a little while will be sent over the weekend :)
Hi Shell still no sign of my order? Do you think I'll receive it before next weekend as I'm going away on holiday. Thanks
dave :laugh:
I need schtickers! Hopefully my member schtuff is in the mail this week.
Dont know why I'm talkin in thisch schtupid accschent, juscht bored at work on a schaturday i schapose. Great cruzsch last schunday guysch!!!
Schaturday, thats funny. :)
Schtupid.....!!!!! :)
Woohoo I've received my pack this morning and already on the car!!! Thanks Shell. :laugh: :PBJ:
Also I've noticed that you sent it in a Postpak which we make for Aussie Post, However we also make our own brand called "Jiffylite" bags. I can offer to SAU special deal on that and even donate a boxfull of samples
as long I get some extra bars below my user name. :sick:
Let me know what you think? Please note I'm away from work till 22nd.
Regards
Dave :laugh:
  • 3 weeks later...
hi guys,
i send my membership stuff at the end of november as well and also still havent recieved my car or my stickers.
just wondering whats the hold up? and how long do u think it will be before they arrive?
cheers
mike
hi guys,
cheers
mike
you get a car when you sign up to SAUNSW now :)
I got jipped!
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
