GTS-TBoy Posted April 6, 2007 Share Posted April 6, 2007 Hey Guys I recently installed a HKS mushroom filter on my S1 R33 (Auto) and noticed that the idle is running rough. Sounds almost like its missing a bit and revs at idle range from 400-900. The power on low end (10-40km) is really shite as well, feels really laggy. This is the only mod i've done to the car, everything else is bone stock. The air filter was put on after a mate tried to get more sound out of the stock BOV. I.e. Plugged the plumb back hose and vented the BOV to atmosphere. We found that the car ran rough as guts, hunting at idle and stalling, but sounded great hahaha, so we put the BOV back to stock plumb back and just bolted on a mushroom filter. Later did some research and heard that stock BOV is always open just a little and idle was hunting due to lack of back pressure. Is this true? My assumption is that the problem will be fixed after installing an after market BOV which stays closed when not venting. Will this fix the problem? Also I haven't reset the ECU after changing to mushroom filter, maybe give that a go???? Cheers Link to comment https://www.sau.com.au/forums/topic/163542-rough-idle-after-pod-install/ Share on other sites More sharing options...
FLY-4DR Posted April 6, 2007 Share Posted April 6, 2007 (edited) When doin the pod u could of bumped or disturber ur Afm, im sorry that itsa basic answer but ive been through 3 afms and all did silly things to my idle, Edited April 6, 2007 by FLY-4DR Link to comment https://www.sau.com.au/forums/topic/163542-rough-idle-after-pod-install/#findComment-3034399 Share on other sites More sharing options...
sky-017 Posted April 7, 2007 Share Posted April 7, 2007 clean your afm with carby cleaner ... or make sure everything is connected well Link to comment https://www.sau.com.au/forums/topic/163542-rough-idle-after-pod-install/#findComment-3034453 Share on other sites More sharing options...
GTS-TBoy Posted April 7, 2007 Author Share Posted April 7, 2007 How do you clean your afm?? Carby cleaner yeah but like do i open it up and spray in there? I would have thought this problem had more to do with air pressure?? Wouldn't know SFA though so any suggestions are welcome. Thanks for the replys so far guys Link to comment https://www.sau.com.au/forums/topic/163542-rough-idle-after-pod-install/#findComment-3034456 Share on other sites More sharing options...
Dobz Posted April 7, 2007 Share Posted April 7, 2007 an aftermarket bov won't allow you to have it atmospheric because vacuum will still be strong enough to open it under normal driving conditions unless you tighten the bov more but then there is no point having a bov if it's too tight to properly vent pressure and cause flutter. when your car is using an AFM its best to keep the bov plumbed back to the intake even if it's aftermarket because you're letting air that the AFM has sensed and added fuel for out of the system causing richness. to put it simply every time you hear the bov vent you would be wasting fuel and your car would not run well. Link to comment https://www.sau.com.au/forums/topic/163542-rough-idle-after-pod-install/#findComment-3034488 Share on other sites More sharing options...
Turbo Dave Posted April 7, 2007 Share Posted April 7, 2007 Air Flow Meter!!! NOT Air Pressure Gauge.......... Link to comment https://www.sau.com.au/forums/topic/163542-rough-idle-after-pod-install/#findComment-3034574 Share on other sites More sharing options...
GTS-TBoy Posted April 7, 2007 Author Share Posted April 7, 2007 Air Flow Meter!!! NOT Air Pressure Gauge.......... Who said Air Pressure Guage?? Can't find it anywhere on the page.... So Dobz..Are you saying that i can't have an atmospheric BOV??? How do other skyline owners do it? Plus i thought you have to have some sort of AFM all the time??? Confused..... Link to comment https://www.sau.com.au/forums/topic/163542-rough-idle-after-pod-install/#findComment-3034654 Share on other sites More sharing options...
sky-017 Posted April 7, 2007 Share Posted April 7, 2007 you can have an atmo BOV , you just need a good one which has a good spring and vents well . yes a lot of people have idle troubles because of them if not setup properly . try adjusting the bov , and watch your idle change . a cheap bov will cause numerous amounts of trouble because they arent made well - hopefully you have a decent one , for your own benifit. here are some things to do : ACC Valve : search ! . you will find a very well written DIY to clean everything out . your idle will run much better . you need carby cleaner for this - its a must ! AFM: clean it with carby cleaner aswell , spray it in the direction of the arrow on the AFM. there could be some debree attatched to it . both of these will definitly help your idle if not fix it . remember to search before you post. Link to comment https://www.sau.com.au/forums/topic/163542-rough-idle-after-pod-install/#findComment-3034666 Share on other sites More sharing options...
MANWHORE Posted April 7, 2007 Share Posted April 7, 2007 clean afm with crc contact cleaner. Then clean the plug too, and make sure you plug it in propelry - you mgith not have pushed it on fully. Link to comment https://www.sau.com.au/forums/topic/163542-rough-idle-after-pod-install/#findComment-3035338 Share on other sites More sharing options...
13thracer Posted April 7, 2007 Share Posted April 7, 2007 seconding MANWHORE please only use contact cleaner on your afm dont use carby cleaner its to harsh. Link to comment https://www.sau.com.au/forums/topic/163542-rough-idle-after-pod-install/#findComment-3035364 Share on other sites More sharing options...
drf76 Posted April 7, 2007 Share Posted April 7, 2007 its most probably due to the bov not being plumbed back as the ecu is expecting that extra air being recirculated, i did the same of my gtst and it ran like crap plumbed it back and it was all good and because i had a pod put on you could still hear the bov pretty loud if thats what ur after. However i seen ppl not run plumb back systems and they ran fine, you can get a extra module to control ur idle etc, ive also seen ppl run two bovs, the original plumbed back and another one to the atmosphere which works too i guess. Link to comment https://www.sau.com.au/forums/topic/163542-rough-idle-after-pod-install/#findComment-3035370 Share on other sites More sharing options...
GTS-TBoy Posted April 7, 2007 Author Share Posted April 7, 2007 The BOV is still plumbed back, changed that back to stock before adding the pod. I noticed last night that it behaves much better at night when the air is cooler than in the day, might sound stupid but it seemed heaps quicker than when stock. It's just in the day time that its really laggy from 0-40km/h. Link to comment https://www.sau.com.au/forums/topic/163542-rough-idle-after-pod-install/#findComment-3035545 Share on other sites More sharing options...
blackprincegts Posted April 8, 2007 Share Posted April 8, 2007 Maybe the super special microchip in the pod is dirty. Try cleaning it and it will not only run better but give you 20 or 30more rwkw's . :laughing-smiley-014: but in all seriousnes just try disconnecting the air flow meter and putting it back in again, also reset the ecu before starting car again. I ave had identical problem twice after mucking around with the pod filter and thats what fixed it for me.. good luck Link to comment https://www.sau.com.au/forums/topic/163542-rough-idle-after-pod-install/#findComment-3035983 Share on other sites More sharing options...
