Hey guys i got a little problem and im not sure what it means?
i was driving last night and seems that when im in low revs and in say a high gear the orange check engine light started flashing quickly and i notice the oil pressure started going from like the second line to over 4 on the oil gauge in the dash? i notice then when getting onto the freeway and acclerating up to the speed limit it done it again and seemed to for the rest of the nite everytime i acceleralted the pressure rose up.
I assume this is a bad bad thing but what is it ?
i got a r33 gtr has power fc n1 oil cooler hks turboes ported head pistons catch can injectors fuel rail 3.5in exhaust standard air flow meters.
help? ...... :D
https://www.sau.com.au/forums/topic/163550-high-oil-pressure/
i got a gtr as well , oil pressure in mine once warmed up is about 2kg on idle about 4kg around 4000rpm and about 6kg at high revs so to me your oil pressure is fine , i had never had the check engine light b4 get it checked out , what are your knock reading ????
Dont worry about your oil pressure it is fine , as u get more rev the oil pump spin faster so it pumps more oil , I dont have a PFC so i cant tell u how to check it but im 99% sure u will be getting a high knock like over over 90 that when your engine will light flash at u
Edited by GTR32GUS
hmmmmm okay did help the read was informative .... its a bar graph on the hand controller but when the bar graph went allmost full it started flashing the light.... mite try the high octane approach thanks gtr32gus.
Sounds like your PowerFC is running a default map or is incorrectly tuned or has forgotten it's map. This can happen if it's a new PowerFC, a second hand PowerFC from another car or if its broken.
Either way if the knock sensors are maxing out the bar graph you are minutes away from popping your motor if you keep driving it like that. You've probably already done considerable damage.
You need to stop driving it and take it to someone who knows what they're doing pronto.
The knock reading on the PowerFC is displaying what the knock sensors in your engine detect. . Knock, also called pinging or pre-ignition and is generally the result of the air-fuel mixture igniting or exploding prematurely. This is obviously going to cause problems in the cylinder if the crank wants to push the piston up but the igniting/exploding and thus expanding air-fuel mixture wants to push the piston down. Results - blown rings, pitted pistons, bent rods, engine damage, none of these are good.
If you really are seeing the engine light flash and the knock reading go way up you really need to stop driving it. Higher octane fuel or octane boost is not going to solve your problem AT ALL.
it seems to only do this when im in high gear and low revs than when i start to acclerate i its reallll boggy and the light comes on when i drive around normally its fine... has done it when i turned the boost up a lil.... ill take it to a tuner when they open up after holidays thanx sewid...
The dyno's ramp rates are too fast to simulate a road condition such as this.
Get it back to the dyno and tell him what its doing and he or maybe she will tune it a little more conservatively.
OR.. Just don't drive in that manner. :)
mine did the same we took out 2 degrees of ignition and it stopped it, it showed a bit of detonation as mentioned earlier......keith
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
    • Do you have a picture? I assume it is a breather for gearbox oil as it expands, it should have a vacuum line run nice and high in the engine bay (R32 GTR has it on a top bellhousing bolt)
    • Hi all, I am putting an r33 gtst gearbox into a VL and have noticed what looks like a vacuum barb on the box (on top in the middle). Suspecting that it's a vacuum line but I'd like to double check, if someone could confirm the function of that would be great. Cheers in advance.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
