  • Replies 292
Posted Images
so we all meetin up today?? (thursday 21st) LoL!
sounds wrong in me saying 'today' coz it feels like tmoro 4 me since ill be goin to bed and wakin up again hahaa!
so anyway, whos in?
yeah tonight sounds good, or fri, or sat!! lol
count me in
i'm down!!!!!!!!!!!!....cars been locked up and haven't driven it at all this week because of going back to uni and it needs a wash!!!...i'm pretty sure a the few people from hoppers that said they were down can come still just need to get in touch with them.
if theres gonna be 6 or more cars there count me in!
forgot to mention maybe just say if ur in or out tonight after my post.
i reckon 8pm would be good ferah if its on tonight...if not enough interest by say 7pm then maybe cancel it for next time.
if the tarneit/hoppers boys are interested lets go down together.
if its on meet at the bp/kfc on derrimut and sayers road just on the round about. watch out for my white 32 and say hi :thumbsup:
Edited by jakez88
yeh well i want to be there also...but don't wanna be the only one there lol...cmon who ever can come out tonight meet at 8pm at watergardens carwash! hoppers people meet up 7 30pm for the cruise to watergardens!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
