They arer the same part as the cheap Greddy replicas on ebay for $200. There is another thread on this, poor casting quality untested performance gain. IMO people making enough power to need an upgraded inlet manifold(over 300rwkw) have spent enough money that most wouldnt skimp on this, they will mostly be fitted to cars that dont get any benefit, only loss in low/midrange torque
Was thinking of shorter intercooler plumbing, tho poor casting quality has most likely put me off. you get what u pay for I suppose. Might be usefull for RB30DET for bonnet clearance. But if you can afford build one of those u'd just buy the Greddy manifold.
We have used 2 Greddy copy plenum's on Rb25's now with no problems at all.
Injectors seal fine and surprisingly it lines up to the head quite well with a little less then 1mm overhang in some places.
Slide id be happy to know about the results you have had with the greddy copy ones and how long have you used them what power you have got with them what the flow on them are like and what boost pressures you are running through them?
1st
One of our standard highflows on a RB25 in an S13 Silvia.
18 psi of boost making 265rwkw.
Coping fine after 3 months
Nismo 555cc injectors
Bosch 040 pump
2nd
GT30R-IW on a RB25 in an R33.
18psi of boost making 278rwkw.
Coping fine after 1 and a half months.
Bosch 040 pump
Plug in Link G3 ecu's were used with both and individual injector duty was the same across all 6 so there were no noticeable pressure differences at this rate of airflow. :)
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
