Hi Guys
Just finished putting in and plumbing up new engine fresh rebuild ,now car will fire and run for about 2 to 5 seconds then stall ,Its getting fuel its fireing otherwise it wouldn't run for those couple seconds it just wont stay running just pulling of the fast idle now to check just looking for ant other idea's I might be missing as to cause of problem
Cheers Peter
https://www.sau.com.au/forums/topic/163575-new-engine-wont-start-ideas/
fill up the tank with a descent amount of fuel,
run the fuel pump in reverse by disconnecting the plug and running the wires to the opposite terminals, only do this for a couple seconds
return to normal
sounds like the filter in your fuel pump has picked up crap, and im guessing there isnt much in the tank right now anyway
Keeper
brand new fuel pump and fresh fuel already in anf brank new fuel filter high flow
Ken
Yes mate going of the dial whilst cranking undolted the line jsut to make sure fuel was getting through and turned it on filled orchie bottle in no time
Kinks
Yes mate plugged in no afm after market computer
Have you tried actually adjusting the fuel and timing settings in the computer.
Generally on a fresh motor, if it's been rebuilt with different injectors, cams etc, you'll need to fiddle with the tune to sustain it running.
Can you keep it running on the throttle at all?
MBS206
the set up was on the old engine nothing's been changed same cms,turbo manifold cam settings just been freshend up.wont run at throttle
dead32
when running is sounds smooth and quiet sounds good for that couple seconds,haltes e11v2 is the ecu needs a laptop to have a look for any errors and I dont have one atm
cheers Peter
rb26s13
I did think of that and checked no
OVL-747
I thought i might have done that but when I took the fuel line off b4 the reg it pumped out fuel like a presure hose
Are there any diagnostics you can do on the e11v2 that would help you out? Give a quick hit on what to look for.
Assuming you are using a MAF sensor make sure it is plumbed in.
Are you interfacing the E11v2 to the Nissan CAS or using a different trigger system? From Halwin open the Trigger Diagnostics page and make sure that your sensor counters are working OK.
For a motronic 60-2 with cam home the "Trigger Count at last Home" should alternate between 57 and 117 for each revolution. I don't know what the Nissan CAS value is since I don't use it.
If your trigger counters are NOT correct ECU can fire the engine on the correct cycle randomly but it will stall almost immediately after.
Wire the fuel pump up on 12V continous power (not from the ECU)
Or at least check what the connections on the ecu are doing (You'll need someone to help)
So the motor was pulled setup with ECU, Injectors, blah blah blah, and you're just rebuilt the bottom end?
What have you done about cams/head? Any porting, larger cams?
Zoltarc
I don't have a laptop to plug into the ecu to do those sort of annalace on the cpu atm just wanna try what I can b4 i get it towed to the tuner
MBS206
the cams are the same hks items the adjustable cam gear settings havn't been touched head was ported in old set up only differance is the 1mm oversized valves and I don't think thats enough to stop it from firing but thanks for the idea's
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
