Hey guys, for early r32 rb20det
Ive replaced coolant temp sensor 2 times, and replaced plug once, i can not find any problem with loom yet ECU still is reading Error 13 (Coolant Temp Sensor) - i know this is ECU pin 28 - what should this read at operating temp, and is there a way to bypass it or trick it into think all is well, as car is running rich as a mofo permanently and is basically undriveable
Edited by 040jqm
https://www.sau.com.au/forums/topic/163585-coolant-temp-sensor-drama/
something simple you may allready know but there is two temp sensors on the engine one for the cluster and one for the ecu the one with the single spade/wire on it is for the cluster and the two pin one is for the ecu.
is the sensor you replaced the two pin one or the single pin one?
cant work out where to find that wire in the loom, as it is all taped and covered in conduit....
it says 1v at 80deg, 3v at 20deg, so can i technically just bridge a wire from pin 27 which is AFM related and should only read from 1-1.5v
just try between the temp sensor and the ecu connector, no need to dig through the loom.
ok checked the voltage at the coolant temp sensor and ecu and they were both the same!!!
They should be
i have reset the ecu, and the code disappears, but comes back a few starts later!!!
According to the good book, error 13 is "Break or short circuit in engine temperature sensor signal system"
I'm guessing you have a break somewhere in the wire, but it only breaks the circuit under some strange orientation condition. I would guess it will be close to the plug onto the sensor. Try wiggling the wire while measuring ohms between the plug and the ECU end.
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
