Hey guys, for early r32 rb20det
Ive replaced coolant temp sensor 2 times, and replaced plug once, i can not find any problem with loom yet ECU still is reading Error 13 (Coolant Temp Sensor) - i know this is ECU pin 28 - what should this read at operating temp, and is there a way to bypass it or trick it into think all is well, as car is running rich as a mofo permanently and is basically undriveable
Edited by 040jqm
https://www.sau.com.au/forums/topic/163585-coolant-temp-sensor-drama/
something simple you may allready know but there is two temp sensors on the engine one for the cluster and one for the ecu the one with the single spade/wire on it is for the cluster and the two pin one is for the ecu.
is the sensor you replaced the two pin one or the single pin one?
cant work out where to find that wire in the loom, as it is all taped and covered in conduit....
it says 1v at 80deg, 3v at 20deg, so can i technically just bridge a wire from pin 27 which is AFM related and should only read from 1-1.5v
just try between the temp sensor and the ecu connector, no need to dig through the loom.
ok checked the voltage at the coolant temp sensor and ecu and they were both the same!!!
They should be
i have reset the ecu, and the code disappears, but comes back a few starts later!!!
According to the good book, error 13 is "Break or short circuit in engine temperature sensor signal system"
I'm guessing you have a break somewhere in the wire, but it only breaks the circuit under some strange orientation condition. I would guess it will be close to the plug onto the sensor. Try wiggling the wire while measuring ohms between the plug and the ECU end.
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
