i want my car to last a long time and i dont want to over push an engine with 100,000ks. these will be my mods. how much power do u guys think i will make.
-pfc
-fmic
-full 3" exhaust (turbo back)
-slide hiflow (going to run 1 bar boost)
-tomei f/pump (in tank)
- stock injectors and fuel reg
-pod filter
-heavy duty single plate clutch
-ebc
https://www.sau.com.au/forums/topic/163607-ive-decided-to-stop-with-the-mods/
if you want it to last dont sacrifice a nice safe street tune for the bragging rights of an extra ten kilowatts or so those mods will make very nice power for a street car look in the rb25 turbo upgrade thread and you will find someone who has close to those mods and see how much there making as a rough guide but every car is different.
If you want your car to last upgrade fuel pump and injectors.
With your current set-up, i'll say maybe 220rwkw. Upgrade injectors and pump then you should make about 240-250rwkw at about 17psi.
The the engine's lifespan all depends on how you drive it and how often you thrash it.
100 ks is not a lot.
A lot of the cars here are are fanging really hard with over 150 000 or even 200 ks.
At the end of the day, replacing the engine with another one from the wreckers will only cost as much as you spent on the pfc + tune (not a lot).
In answer to your question, the limit will be the stock afm and injectors. Probably around 210-220 rwkw.
1 bar on that turbo will be a bit much i think. Maybe around 12-13psi will be more like it.
Is that due to his fuel system or do you think the turbo is not up to the task of higher boost?
I used 18psi on my hi-flow without a problem.
Just keep in mind if you go above 14psi you more than halve the engine life.. So if you reckon its got 2 years left in it, relatively speaking.... Cut that proposionatley by your boost............ Low boost and a good setup will see you dust most big dollar cars to 100kmh....... After that let them cry to there mumma's.......
I used 18psi on my hi-flow with a problem.
Nah, the turbo is more than up to the task. Those ones fang mate. It's just that your injectors/stock afm could be maxing out. Since the turbo flows so much more than stock, 12-13 psi on that turbo could be as much as 15-16 psi on the stock turbo.
so it should make 210-220 at that boost.
Edit: as slide said above
Edited by MANWHORE
Ah.... what makes you think that? Engine life has been discussed, and it's never a simple formula. You could have bad luck happen like snap the cam belt, and the engine is gone.
Or if you're sitting up at the limiter all day doing burnouts/drifting, it won't last as long as a modded engine that's driven easily.
As I always believe, buy a good car, look after the engine, treat it well, and it'll look after you. By treating it well, i don't mean drive like a granny. I mean service it with good oil, and frequently. Have it tuned well. Drive hard, but don't sit at the limiter. I fang my car hard, but i take these above factors into account.
Cannot disagree more with that comment. The reliability of an engine has to do with a lot of things, boost is one of them...but i wouldnt even rate it in the top 5!
2 years tops? :)
I had my car running 17 pounds of boost all day every day for over 3 years and the engine was in top notch condition. The car had over 150,000 on it + i had standard afm and injectors making 250rwkw.
Edited by krzysiu
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
