As a first time owner of an R33 gts25t series II,, i was wondering if there is any major service items I should be looking at like timing chain or the like. Also, could someone point me in the best direction for a service manual. Thanks, Kirsty. It has done 124000kms.
https://www.sau.com.au/forums/topic/163615-new-r33-gst25t-owner/
Hi and congrats on your purchase.. I have an R33 and love it.. I've just rebuilt my engine myself and it was a great experience. Id do it again.
You really should be changing some things under the bonnet by now if the previous owner hasn't already done so. Your Skyline doesn't actually have a timing chain, just a belt. You can pick one of those up from anywhere between $100 - $400..
You don't have to spend $400 though. I brought the Greddy timing belt online from Nugen for $114.. A good belt.
-Get someone or yourself to check the spark plugs as well... they will prob need changing. if you decide to change them, put in some decent ones as the spark plugs are a little more time consuming to get to on the Skylines compared to your average car.
-Check your oil and coolent as well.. Your coolent should be a nice (alomst flouresant) green and if the oil is black black and seems to be thining, then you should probably change it as well.
Because you probably don't know the service history 100%, I'd do all of these just so you have a service point which you can work with. Don't forget to change the oil filter when you change the oil....
-Maybe someone can clarify this for me but I'm pretty sure that they recommend a water pump change as well... Probably don't HAVE to but they may recommend it if you ask....
This is what I wold do if I were in your position. Go and get some professional advice if you like but a lot of your everyday mechanics don't seem to know much, if anything about Skylines.. You could always find someone who specialises in Skylines, etc.. Check out the forums.. there is heaps of info here to help you out.
GOOD LUCK!!
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
