Forsale
1993 R32 Gts-4
Colour: Maroon
Man/Auto: Manual
Km's: 102,000kms
aspiration: Turbo
features:
ABS
Sunroof
Tinted Windows
Momo millenium steering wheel
nismo leather gearknob
nismo floor mats
interior condition is great
exterior is fair to good, slightly bent front right fender, paint is good in most parts, but fair in others
Mods:
-turbo back exhaust
-ISC fully adjustable coilover suspension, height and 32 way damper/rebound adjustable settings
-brand new Exceedy GTR heavy duty clutch (500km old)
-freshly machined flywheel also
-new gearbox with redline shockproof gearbox oil (also 500km old)
-rebuilt head, new valvestem seals etc, machined head
-Tomei 1.5mm metal headgasket (rrp $600)
-GTR fuel pump
fresh components on the car include;
- Brand new radiator and cap
- Brand new hoses (every single hose in engine bay, from radiator hoses, to heater hoses, to fuel lines etc etc etc)
- every single gasket in engine bay replaced (from headgasket, mainfold gaskets, all turbo gaskets, rocker cover gasket, half moon seals list goes on!)
- Brand new rear main seal
- Brand new Water pump
- Brand new thermostat
- Brand new clutch fan
- Brand new timing belt
- Brand new idler / tensioner pulleys
- Brand new Clutch master cylinder
- Brand new Clutch slave cylinder
- all fluids have been flushed, replaced and bled
^^^^ all done 500km ago
when car was running it made ~150psi accross all 6 cylinders on a comp test.
heaps of work has gone into this car
and now, cant afford to replace a main end bearing that has gone! this is the reason why the car must go at a cheap price, because this must be fixed in order to have it working!
either perfect for a mechanic to buy who can fix the problem very cheaply and have an excelent gts4 or someone looking for a cheap r32 to drop an rb26 into! as it has the running gear all set up to take a gtr engine! as it already has the gearbox, clutch and all!
Asking price $9,900 NEW PRICE $9,000 Negotiable
located in Melbourne
contact me on 0408569685
or pm me
MORE PICS HERE
Pic4
Pic5
Pic6
Pic7
Pic8
Edited by Ruffels
https://www.sau.com.au/forums/topic/163626-1993-r32-gts-4-turbo-manual-9000/
umm not 100% sure, i think your better off putting a 2nd hand motor in for ~$1000 ... you could replace the bearings for bout $300 ... but thats probably only a short term fix
More Pictures added!
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
