Just purchased a greddy copy plenum for my r33, for a decent price, it Should arive this week, this week i will prep the unit a little smooth it out a little and take the grooling challenge to prove some things for you guys Ive noticed teazn_33 is doing it and i thought hey bugger it for the price i may as well attempt this one to settle all non believers and also believers out there as there is alot of sceptism out there about these units is there not? I have previous before hand dyno results in my hand here so will be able to do a before after result for this unit. Slide says he has used them successfully so theres another backer for that there is not much wrong with them, Will take photos before during and after the process, will take photos of the before and after dyno graphs.
Boost pressure i will be running will be 16-18 psi varient
Turbo: If you dont know it is the HKS 3037pro s
And this will be with the standard throttle body (First)
I will also keep you people update with problems that i may have or have along the way, I will take photos of Installation and documentation.
This may or may not help for later on the track, And if teazn gets his result first good on him, at least 2 or 3 of this nature is better than all the sceptics out there and stuff floating around.
Last note: I do not want flamming ive heard and seen all that rubbish before hand, im doing this out of my own will and nature, and this will hopefully close some things people have going through there minds
So watch this space. #3week deadline :)
Thankyou very much :yes:
Merry Easter
Adam
  • Replies 55
be good to see if there is a difference because I have the greddy plenum in my car but I did heaps of mods at the same time so I don't know if it made a difference or not.
What size cooler piping are you going to use and are you going to up grade the throttle body size ?? why are ask is because ive upgraded the the size of the piping by like twice its normal size and got a Q45 throttle body and its like 90mm or something and the car is laggy as especially off the line, but when she gets to 4 grand she takes off
Ill be watching this thread to see how you but I think ill have to get the 3.0l bottom end to fix the problem (I Need more cubes)
First step is use the standard throttle, as most people have got these later will move to bigger but not yet want the basics out first, cooler piping well at an estimate with this design shall eliminate almost 2.5 ft of current piping from cooler to tb which is 2.5 inch wide, my power band at the moment would have to say its not laggy at all as good turbo small rear with a .68 a/r rear housing so well starts at less than 2800rpm build to boost by 3500 max at 16 to 18 psi Time frame im hoping after i do a little prep to it most likely 3 weeks to the end of this month. So soon
Cheers A
hey, guys those copy things are cheap but is shit. I bought those few month ago, u need to get some1 to tidy the surface, especially the face that attach to the engine block, is damn rough all around u can c little tiny hole on the top or too much on the bottom. It 100% need to be tidy up b4 u fit, as i tried to save that hundred buck and fitted and start, fuel and air leaking from the intake. Finally i told myself, do it once , do it right so bought the genuine greddy, u can tell the different.
This is the reason why i did buy one so i can prove it to be a ok or not thing, and i didnt say i wasnt going to do a little prep myself :yes: thanks for your input james have a nice day. Oh i have to ask james, where did you buy who off, did you contact them, how did they respond all these little things did you take photos, did you try to clean it up, how did you go. All these little things james, please read at the top ive seen and heard all the sceptic shizen before hand im doing this for a reason, so unless i have useful comments :P please dont comment not to be harsh to people, but you get the general idea ;)
On old thing would be aswell:
If you buy 10 apples and the first one is bad do you throw the rest out and call it a bad batch or do you test to see the other ones are ripe/good? Maybe you may have had the bad one out of the many which are produced, i know first hand that there are many out there that work, and few that dont this is also why i am testing this. Ive done my research i know how to take this challenge on im not a no brainer person :O Thankyou
how hard would u rekon it'll be to modify the stock inlet manifold to a front facing rather than side facing??
u know it bolts up right, all the holes are there, u could possibly go some extra porting,etc. hmmmm.......this is giving me a good idea!
say if u buy a greddy copy for $250, it wouldn't cost you not even close to that figure to get a fabricating company to modify the stock inlet for ya
sorry Devils_Advocate2 im not flamming u or trying to hijack ur thread, but u rekon its possible to do?
The stock inlet is a bastard to modify inn the same style as these ones, and it would cost a lot more then $250
Ive seen that done once, i dont know who by but it would be an absolute prick of a thing to do as there is vacuum lines in the way aswell as you'll have to plug the factory hole up as well, so in excess of 300 plus ill put that down too. plus to re align everything would be a pain aswell
Cheers
A
This would be one thing ill be looking at in this process as well just may get it flow tested in the process we will see.
The problem most often stated is uneven distribution of air to the cylinders.
Good luck with the trial.
Please do put it on a flow bench and see. I would like to see this one either confirmed or debunked as myth.
FWIW, I'd think it a waste of time if you didn't use your time and make sure it is port matched and tidied up.
Keeping an eye on your progress as well. :stupid:
id like to say to say its good to finally see someone put this to the tests and see actual results not "my auntys dogs cousins sister said that her friends sisters boyfreind tried this and it was crap or......it made 1 million kw on 2psi with this being the only upgrade" lol. will be following your results goodluck
    • If you want to do a single throttle body conversion easily, you won't need to pull anything apart. Take the linkage from your throttle off the linkage controlling the ITBs. Now open the ITBs wide open, and lock the linkages in said position. Now add a single throttle body onto the front of your inlet plenum. No it's not ideal for the last nth of a kw, but it'll be a lot better than what you're already trying to do...   PS, ITBs can be so damn hard to tune from, because roughly 20% movement in a throttle body equates to a change in roughly 80% of its flow (Hence power). When you add up the flow limitations of those small throttle bodys, it is a LOT higher than that of a single large throttle. Hence, TPS is very very sensitive with them, and you do a LOT of work with sensor fusion, and some Maths behind the scenes to make those blends nice, and be smooth.
    • Yep, when Haltech purchased Adaptronic, and all of the Adaptronic staff, including Andy went with it, it took Haltech to the next level. Haltech wanted Adaptronic as they wanted things like Andy's fuel models, and some other IP, AND they wanted Andy too as he is brilliant! Andy has spoken about the incompatibilities between the old 1500 stuff vs Nexxus, and it totally makes sense. It's not JUST software that is different, there is huge changes in the underlying hardware too. It's why Haltech has had soooo many changes in the last couple of years, in terms of Hardware, and Software, and why it has become so damn Amazing. Why do you think guys like Rob Dahm with his quad rotor, went from running Adaptronic's to running Haltechs? Andy. Pretty much, Haltech these days, is Adaptronic, but with more funds behind it, and more staff, and hence Andy's visions, and visions of other people that he helps shape their great visions, into amazing new products. All the new Nexxus gear, whole new software for it, new and better dashboards, the apps that will run on headunits and NOT be slow to respond! I understand people being burnt in the past, but if you're ragging on a company, about products and issues from many years ago, it's more a reflection on yourself, not looking or keeping up with new stuff. In which case, those people should be going back to PowerFC and Nistunes as the ECU's to rave on about...
    • Right, but I thought the problem has been for a while now that even if you know manifold pressure + throttle position you still have non-linearity and aliasing issues vs actual engine load? One way I can see things simplifying is going DBW, then all air going into the engine is represented by the throttle position. As opposed to a random bimetallic strip vaguely linked to engine temperature opening and closing a shutter or some random power steering air valve suddenly allowing a bunch of bypass air. But the same throttle position/RPM at ~atmospheric MAP in different gears is not guaranteed to be same engine load? Honestly, ITBs are of such dubious value IMO. I don't know why these things are hyped up so much. The main benefit as far as I can tell is you reduce the likelihood of cross-cylinder EGR scavenging with significant cam overlap at idle. I would absolutely run speed density and be done with it if not for this fairly esoteric control problem.
    • Hah dont worry, my adult brain has this conversation every single day. Dont waste your money, invest more of it into shares, pay down the mortgage. Then the bedtime insta doom scrolling begins and after being bombarded with gtr's my mind is set: im definitely getting one! I have the current model mx5 as the weekender, but i just miss my boost and literally like your username, the sututu's that come with it. I remember with my 2nd supra, as it had twins and vvti, they used to spool real early, like 1,500rpm so you could just be a spooly boy all day long. Some people say they get over it after a while, not me tho.
    • If you need to refinance your mortgage and reset the loan terms back to 30 years and cash out on your equity for "investment" purposes *cough* car parts, I can help 😊
