Traction is a prob so a clutch that could be ridden a bit would be better but i dont know if you can get a clutch you can ride that still wont wear out
$750 is a bit steap for me apperently daiken do brassy's for 500
i gotta decide soon though it's startin to slip really bad though a commondore almost kept up with me. hehe
https://www.sau.com.au/forums/topic/16368-brassy-clutches/#findComment-336046
Originally posted by Bl4cK32
I've got a brassy in my 32, and have had no trouble with it. It is true, you do have to give it sum then dump it. Only thing its a bitch in carparks, or goin slow in general....not that I go slow.
hey black32 ive got a balck32 too hehe:D
i dont mind so much the parking and the slow driving hassels it will cause that jus goes with the territory likethe rest of the hassals that go along with hi-po cars.
Not that im complaining or anything i wouldnt have it any onther way
My biggest concern is take-offs as traction is a problem already
do you find that your tiptoeing on take offs or are you still able to drill it off the mark???
https://www.sau.com.au/forums/topic/16368-brassy-clutches/#findComment-337548
I can take off like normal, without tiptoeing it, as well as drilling it whenevr I want.
Give yourself a month to get used to it though.
BTW I've got my car in the shop now coz it split the clutch hose due to it being old, and the clutch is heavy as, so replace it when you do the upgrade.
https://www.sau.com.au/forums/topic/16368-brassy-clutches/#findComment-337750
When i installed my puck clutch i wish instead i had installed an R32 GTR OE clutch. Im sure it would hold the power of stock turbo, even up to 200kw with small aftermarket turbo.
It would have all the driveability of stock unit, handle some moderate abuse (any clutch can be fried) and would have been cheaper.
Whether the puck clutch is that much harder on the drivetrain or not, i dont know. I suspect they are as they sure as hell sound/feels like it, so cant imagine the gearbox/driveshafts/diff are immune to additional loading transmitted thru the drivetrain.
https://www.sau.com.au/forums/topic/16368-brassy-clutches/#findComment-337809
brass button clutches can destroy diff's, axles, tailshafts, and gearboxes.
i am getting a 1 piece tailshaft, and if i blow up my diff, i will just get a mini spool.
but when you are building a performance car the brass button cluth does give u better acces to the power.
either clutch is good for the power though.
just like saying how longs a piece of string.
many answers
https://www.sau.com.au/forums/topic/16368-brassy-clutches/#findComment-337856
i have never driven a twin plate, but a friend with a r32 gtr has a twin plate, and he says it is also on/off.
you cant ride any clutch and expect it to be good for it. But the full face clutches are just easier to do it in.
twin plates are very expensive, and not really warranted for say 200rwkw. if you can afford it twin plates are better than brass buttons, but not really warranted unless you got a hipo motor to back it up.
https://www.sau.com.au/forums/topic/16368-brassy-clutches/#findComment-337870
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
    • Just putting it out there, that's a decent list. You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
    • Does not mean what you think it means. The continual rising coefficient is the coefficient of friction that continues to rise with increasing temperature. Not "rising during a single stop", except inasmuch as the brakes should get hotter during a single stop. The RR would not be the best choice for a streeter. Yeah....no it's not. JAX would rummage around in the "shit pads we use for all shitboxen that come in here" and install those.
