I have been looking a the Turbotech boost controller for $30 off Ebay and the Turbosmart Boost Tee for about $100, basically Im unsure which is the go as both these producers claim the same qualities such as quicker spool, better response at low rpm, etc, etc.
Is there any real reason to justify the $70 price difference between these 2, has anyone had experieneces with either or both, good things/bad things? The thread "I found a good cheap boost controller for $22" says alot about the Turbotech but is the Turbosmart just as good or any better?
https://www.sau.com.au/forums/topic/163698-turbosmart-boost-tee-vs-turbtech/
Yep turbosmart one sucks, mine lasted 6 months and now have a GFB which is better but is soon to be replaced with a Greddy Profec B spec 2.
If I wasn't going for a EBC, would have gone the Turbotech, heard such good reports about them.
Fair enough, and I have been hearing of some with the hole and without the hole? Have you guys found it to affect it at all??
Have a read of this thread. The last few pages has alot of discussion on hole vs no hole.
http://www.skylinesaustralia.com/forums/in...showtopic=73375
either way, this is by far the cheapest and most effective manual boost controller.
if your getting a fumble on boost , you will need to drill a 1.5 mm hole , to release air so it doesnt get stuck between the waistgate actuator. some of them had like a 08. mm hole , some dont . if your experience troubles make it bigger . also there is a possibility you will need to regap your spark plugs if your getting a missfire , and also check your coilpacks for cracks.
I had a turbotech controller and it was great, worked fine (I did get some boost dropping off over 6000rpm but I think that was due to the the restrictive front pipe and cat). The only reason I removed the turbotech controller is that I was given a ProfecB Spec2. The turbotech controller is being passed on to my mates apprentice :(
Yeh thats my only concern, can you show me on a pic or explain where the hole should go?
the hole goes directly opposite the barb not the barb opposite the screw end, the other one.. there is only one place you can drill that is a part of the body that is opposite the barb. I emailed the guy and asked that question. i drilled a 1mm and he said thats fine as long as it aint bigger than 1.5 mm as thats what he uses
mine was crappy after gear changes but fixed with that hole. as other have said best 30 bucks spent
I heard the new boost tee (not the old bleed tap style) is basically a rip off of the turbo tech ... so basically the same thing but probally better engineered.
I've also heard that the turbosmart product is much easier to adjust ... a step by step locking adjustment style ... rather than a screw and a lock nut which is hard to adjust ... once adjusted though they should both work equally well.
If it was me id buy the turbosmart one as you most probally are going to get better support and product
Just buy the Turbotech one, or spend even more and get an EBC. No point spending $100 on a MBC when the Turbotech works so well. I had one up until recently and it worked perfectly.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
