shold i rip that wing off????
62 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
well she was black, But got sick of that! too hard to keep clean....
umm the colour is ford blueprint 6000S
with house of colour flake,topped off with 6 coats of house of colour super clear!
This clear is the most stinky shit, but man its got some gloss, and its ment to be crack, chip, and chemical resistant!!
I got some VX holden side blinkers, modded the hood and got my self a GTR grill from japan! welded up the holes in the boot and fitted my drift wing... i did want to get a VS wing but at the time i didnt have the cash so i go the old drifter wing out from hiding and installed it!
so from this:
the inside parts and the motor pipes ect have been painted as well!!! tell me what ya think guys!
to this:
to finished!
some NEW PICS
Edited by kezza
https://www.sau.com.au/forums/topic/163704-my-32-is-nowwww-blueeee/
  • Replies 46
Posted Images
lets not get started about the painter.... :P a few things im not happy with.. but yeah i helped do all the small stuff, like stripping the mags, painting them... in inside stuff, and the pipe work ect!
Im very happy with it non the less!
turns heads, but not too over the top!
Wow!! That looks hot!!
Personally, I'm not a big fan of the drift wing, I think the Daewoo that gets around ipswich with one on it ruins it for me... But each to their own!!! Why not just go wingless???
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
