ok well im new to skylines (owned an s14 and currently a 180) and someone is keen to swap an auto 4 door 34 gtt for my car and some money. Im a bit concerned about the km's. its a 1999 with 150,000 ks or there abouts but is pretty much stock and never run more than stock boost. should i be concerned about such high k's on a 34?
also how are the tiptronic autos. it has the paddle shift. anyone had any experiences with these?
thanks
https://www.sau.com.au/forums/topic/163714-some-r34-questions/
I absolutely love my tiptronic R34 - the only people who don't like them are ones who haven't driven them :yes:
Never again stall at the lights or stuff up your launch, never miss a gear again, you can change gears in the middle of a corner when hammering through the hills without your hand leaving the wheel, rev out longer in each gear, etc etc.
And I haven't done the valve body upgrade yet, but this makes the gear changes even quicker and harder. Add an uprated stall converter and no manual will come even close to keeping up with you with the same power.
Plus you can drive like a nanna when you want to just putt around in full auto mode. :P
I have had a triptronic and manaul 34. Triptronics are nice, but the shift just didn't really do it for me. I much prefer the manual. If your happy with triptronic buy one, but make sure you don't just take other peoples word for how good they are as it might not suit your driving style.
Tiptronic's good mate! Gets off the line bloody quick too. I was specifically after the tiptronic when hunting for a car.. i do mainly city driving. Now time to get a MV shift kit for it and burn some tread :P
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
    • Well found out it’s a 60th anniversary gtst from that it came with 205-55r15
