Hi, i'm wondering if someone can help me, i want to buy a set of rims from aus, from a private seller, but i have to arrange all shipping and stuff, how in the hell do i do that and who do i contact?? i have looked up some hsipping places and stuff, buts its so confusing... I need someone to put it all in laymans terms. Can anyone help me...!!!!???
hey, if its anything like buying rims from japan. you can just use the normal post office (australia post). you have two methods for shipping;
1.air
2.sea
Sea, should cost you about $300 (for 4x rims which weight about 7-9kg yet), you will be look about $600-$800 for shipping by air. (aus dollars)
Here are some helpful Website which should tell you everything you need to know
http://www.auspost.com.au/
http://www.auspost.com.au/IXP/0,1465,CH4030%257EMO19,00.html --- International Services
http://www.auspost.com.au/BCP/0,1467,CH4038%257EMO19,00.html ---Sea Mail Parcels Information
Hope That Helps :stupid: Cheers Michael
you can go with that option or u can go with an international shipping company like DHL or FEDEX they ship worldwide they give u tracking number so u can see where the package is and how long it is goin to take...... so i suggest checking out DHL or FEDEX websites to find out how much the cost is to ship from australia to canada...... also i would get the private seller ur getting the rims off to remove the tyres as the tyres on it will be made to suit australian road standards and wont be legal in ur neck of the woods..... this will also reduce the weight in the package.....
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
