Here is the Excel file I used to map my Fuel and ignition tables. I am sure some of you guys out there can get some use out of it. I recently had Mick from subzero Dyno my car. You can clearly see the fuel he took out of it at PFC load Value 15-16. The car was being retuned at 1.10bar. The Ignition points around 15-16 need to be trimmed at peak torque to reduce detenation. Did make 225kw tho. When the timing is retarded I think it will negate the extra boost and all I`ll end up with is a slight increase in mid range power only, probably actually loose some up top.
https://www.sau.com.au/forums/topic/16374-power-fc-chart-mapping/
  • Replies 58
HKS Super Dragger Ex
HKS Dump Pipe
mesh removed from A/F meter (stock r33)
Apexi Air filter /partitioned off
Greddy 28c tube and fin front mount intercooler
Heat wrapped turbo to cat*
*cat in pipe
heat wrapped intake pipe
Power FC
HKS solid twin plate clutch
Cut out front bar
Oil air seperator
Bosch Motorsport fuel pump
Motul 5w40 oil
Nulon G70 with auto trans fluid in the gear box
1bar to 1.10bar boost
HKS EVC4
Pureone oil filter
Stupidly huge fuel filter
BPES7??? plugs 0.7mm
BP ultimate 98 Fuel 1bar- with octane booster for 1.1bar,also another 2degrees added with octane booster.
I`ll modify this post if I can think of any more
  Quote
Originally posted by Steve
225kw with stock turbo!  1.1bar with stock turbo!!!! you're a very brave man:)
Your right on the money Steve, I only get near those figures with a healthy dose of octane booster and I still get a minor ping. I`m taking it down AIR for the next street meet. Fingers crossed I can get through another 6 passes.
Thanks boostd useful info.
I actually leaned out the fuel map at idle to try and reduce exhaust fumes (I don't have a cat fitted). Hunts a bit now (I took the AFM screens out also), but less likely to gas myself whilst idling in a semi-closed garage.
I'll drop my maps in for the RB26 and post here also.
Anyone else got RB26 maps?
Its Greg from base. What do you reckon try loading your figures into my car. Where could I go wrong. Our cars have the same mods virtually. Mine has only had one tune for an hour on a 43degree day. So there is nothing to loose. I am planning a turbo upgrade in the near future so it will have a retune then.
